VW MKIV Jetta VR6 12v Mishimoto Radiator - Only $255.00
Improving performance by increasing engine work is only possible when engine temperatures are kept within a reasonable range.
The Mishimoto Performance Radiator is capable of a 35% increase in cooling capacity due to a fully-brazed, two-row aluminum core that's 25% thicker than stock. This radiator also uses CNC-machined quick-disconnect fittings for a perfect radiator hose attachment.
Heat is for fuel economy, while cold is for power and longevity. Get the most out of your 6 cylinder with this low temperature thermostat!
