So let me get this straight, the tyre width can't be more than 26mm wider than stock, but there is no restriction on the size of the rim itself (so long as I match it with a low enough profile so as not to have the whole thing wider than 15mm from stock...
So I can go from 15" rims with a 4" profile tyre for a total of 19" of diameter to say a 18" rim as long as I can find a 1" profile tyre right?
*Numbers are made up for argument sake.
And that also means that for a VR6 who standard wheel is 6" / 6-1/2" wide you can only run a 7" - 7-1/2" tyre.
In other words, the law doesn't care if you want to run 20" rims with rubber painted on the outside, the problem is that they are too wide?
