I live near act , wondering where i could get some eibach pro lift springs for a 4motion tiguan .
Any body know best place to get eibach springs
When I wanted to buy an Eibach pro kit I found it best to deal with Eibach direct.
The lady (can't remember her name) was very helpful and I had them the next day.
Just ring them on the number in the link below and they will help you out.
Contact - Eibach SpringsMKV Sportsline Soot Belcher
MKV Jetta FSI DSG
If you're not in a major hurry you can often save a few $ on ebay.de (you often won't pick this up in "normal" searches as the sites will be filtered out due to language).
I bought mine off an ebay.de seller and had no issues. Try these for example: Eibach Springs Pro-Kit Federn VW TIGUAN (5N_) 30/30mm Tieferlegung | eBay
OK sorry - I just searched for Eibach & Tiguan.
Main comment was that you can often find the Eibach springs cheaper in Germany. You'll have to search around for the lift kit if that's the ones you're after, as they are not as common.Last edited by tigger73; 29-12-2015, 01:41 PM.
Who would do such a thing - use an SUV for off-road????
I didn't realise Eibach made such a thing.Originally posted by vwpolo View PostThanks tigger73 but the link goes to lowered springs , i want the raised ones i live in regional nsw and need the height
/searches catalogue... partno E30-85-020-02-22 ???? I think you'll find they are "buy-in" only.
H&R do a lift spring or
you could fit Spaccer spring spacers.
KYB do a heavy duty rear but I think it's OEM height & an increased spring rate.
You could also get custom springs made locally. K-Mac will do it however you want.
NB: if you go too high at the front (50mm +) the dampers will top out on sag. You'll also have problems getting enough negative camber. You can probably fix it with Audi TT control arms but be aware you are venturing onto the slippery slope of mods
I also suggest you increase the tyre diameter to the maximum legal when you buy tyres - that will give an extra 7-10mm clearance.carandimage The place where Off-Topic is On-Topic
