Lug bolt Plastic Caps not fitting! Mk6 GTI
  • Lug bolt Plastic Caps not fitting! Mk6 GTI
    Hi all, just put on some 19" talladega replicas on my mk6 golf gti - used the same bolts etc. However, the plastic caps that go over the bolts no longer fit, too large! Any solution, will VW dealer have smaller caps?
    Sorry if this is a stupid question, first time I have come across this. Thanks
    Current: '11 Renault Megane RS 250 Cup Trophee - Manual - All Options - Stage 1 Bluefin
    Ex: '10 Nissan 370Z - Coupe - Manual
    Ex Ex: '10 VW Golf GTI - 3 Door - Manual - All Options - Stage 1 Bluefin
    I feel your pain bro, I'm in the same boat, I'm gonna buy some black bolts, they will still look good.
    Btw did you find a solution?
      Easiest and most common way to sort this out, is to instead of using the stock covers, make your own out of sikaflex. Just squirt it around the bolts in the bolt holes until they are completely covered. Then simply smooth it out. Looks much better.
      Sent from my GT-I9305T using Tapatalk 2
        I had the same issue when switching to aftermarket rims. Ended up getting a set of black covers from ebay uk. A set cost around $25 all up, and fit perfectly.
        These are the ones I bought if it helps:
        UAS Black Wheel Bolt NUT CAP Cover SET 17mm HEX 20 Pieces Plus Removal Tool | eBay
        2010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
          How exactly do you get the Sikaflex out afterwards?
            My thoughts exactly lol
              The trick is to spray the bolts/surrounding area with hairspray before applying the sikaflex. Will pop out easily that way. This is how everyone in the states does it
