Rear Camber
  • #16
    Originally posted by Golf Houso View Post
    Wow, please keep us updated How much work is it to install camber shims btw?
    By my understanding it involves resetting the hub. Ie taking off the wheel, brakes, disc, blah blah blah, putting on the shim and then reversal. Wouldn't be TOO much if you really wanted to do it, but personally I'd probably not do it straight away...I'd have to find a day where I'm REALLY keen to do it
    • #17
      Don't think you can add shims behind a rotating axle. With the rear beam setup, the camber shims are located behind the stub axles.
      Present: Mk3 Golf variant.
      • #18
        dub 20v is having his fitted at the moment should have around 1.5 neg camber you can get them from regal motorsport...
        a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
        • #19
          got camber?
          • #20
            I had a feeling that was the case, what about camber bolts I remember you mentioning those before?
            And does that car even move or does it just sit in his yard so he can take pictures of it
            • #21
              Camber bolts are for the fronts. Camber up front is adjusted on the strut with two big bolts that have a little play in them. You can't really adjust them to get huge negative or positive camber, it's mainly for alignment...so then when you have bad camber alignment you can get special bolts that help adjust it MORE so you can get the wheel straight.
              If that car moved, the tyres would need replacements weekly..
