I can't see any reason why they physically wouldn't fit.
MK6 TSI running MK6 GTI Suspension
Originally posted by Lucas_R View PostInterested in a set of Golf R springs? Im doing a bit of a clean out and thought i may as well sell the springs. They have done about 8,000-9,000kms.
Originally posted by Procurement View Postbut would you mind me asking how much the H&R's were?
If you are looking for dampers & springs then you may as well get coilovers & be done with it.
There is nothing particularly special about the spring/damper combo fitted to a GTIcarandimage The place where Off-Topic is On-Topic
Originally posted by brad View PostIf you are looking for dampers & springs then you may as well get coilovers & be done with it.
Originally posted by Procurement View PostSTOP IT! That's evil talk Brad. Besides my wife will divorce me if I start doing any upgrades. I would love to get coil overs but current budget doesnt allow so GTI suspension it is. Perhaps if I was driving a GTI or an R I could justify the upgrade......
I don't recall if you said you will DIY or pay for the install. If DIY then go crazy but budget on getting an alignment done every time you R&R the front end.
If you are paying then count on the mechanic charging 1.5-2 hrs for the front spring change (with or without dampers) & .5hr for the rear spring change + 0.5-0.75 hr for the dampers.
Depending on how many km you have done, heavier springs will accelerate the wear in your stock dampers. At best, you'll get about 100,000km with your current setup before (front end especially) starts bobbing around a bit much (sure, most people will put up with it & be oblivious). Assuming you have about 40,000km now, you'll probably get 20k-40k if you just do springs - the heavier the spring rate, the quicker the wear.
If you can find a complete set of GTI dampers & springs, great but don't expect any amazing leap forward in handling & the drop will be almost un-noticeable.
Coil-overs can be had at quite reasonable prices - like $600-ish. I would have gone that route except I already had the Eibachs.carandimage The place where Off-Topic is On-Topic
