wheel shop in Melbourne to re drill wheels.
  • wheel shop in Melbourne to re drill wheels.
    I have a set of 16x7+35 and 16x8+35 work equips, at the moment they are 5 x 114.3 I am looking for someone to fill and re drill these to a 5x100. Who have people used in Melbourne and what did you think of them?
    RE: wheel shop in Melbourne to re drill wheels.
    I would not like to redrill wheels. If you must use them, then get some adapters.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
      I wouldnt be redrilling equips as you will see the two lots of bolt holes
      Bora gone
      Vento VR6
      MKIV GSW TDI
      7P Touareg TDI
        I have seen alot of people do it Greg so I assumed it must work ok?
        Dylan, the will need to be filled and then drilled, although I don't know how it all works exactly I thought they must fill the original holes and then drill new ones?
          The whole face will have to be filled by welding, cut back flat both on the face and mounting face, new recess in the face, then new holes drill in the recess. Don't think you would find many people willing to do that.
          Dunno if even the likes of rotiform would
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            It's possible, but potentially you would be more looking at a 'plug and drill', where are bolt hole is dramatically opened up, and a new plug squeezed in, then the new patten redrilled.
              Maybe I'll just keep them in the garage and buy some 5x100 wheels
                just use adapters?
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                  just use adapters?
                  The wheels are 16x7 and 16x8 + 35 I'm **** with offsets, do you have any idea what size spacers I will need for a mk3 vr6?
                    I gotta my te37 redrilled it only cost $50. Wheelmods in ferntree gully they would definitely look after you mate. Btw personally I wouldn’t do adaptors due to the fact at certain speed you feel a lot of vibration.
                      And then there is this when I asked the Authorities
                      Can an engineer overule the regs and certify a car to use spacers.
                      A wheel spacer cannot be engineered in Queensland. The only way to have a spacer/adaptor is if it was released from the manufacturer.
                      Adapters which are different to spacers are not mentioned. They are bolted to the hub and have different studs for the rim to attach with They also have a center hub to locate the wheel that spacers generally don’t have.
                      Adaptors are treated the same as spaces even though they bolt to the hub they still result in spacing the wheel face from the hub. Therefore, if they are fitted or mounted to the original manufactures rotor they would not be acceptable
                        You obviously didn't have hubcentric adapters.
                        Or your wheels weren't balanced.
