Which wheels will fit
This is a sticky topic.
  • #91
    hey peoples,
    will holden 2008 commodore SS rims fit a 2009 VW TRansporter? The STud Patterms are the same and the offsets are off by 7mm... will this make a huge difference when fitting?
    • #92
      Hey all.. hope this is the right spot to put this is..
      Ive got a set of BBS Style 5's (off a bmw 5 series) the size is 17x8 and 17x9 et20(i think)
      With a 20mm adapter, will this fit my VW MK4 golf fine? or would it need work?
      cheers
      • #93
        My understanding is: Add adapters, You lose et, so you'd end up at 0 offset.
        The style 5's wouldn't work unless it was an E36 version as they had a higher offset usually around the high 30's. 5 Series have lower offset.
        • #94
          Thanks for the reply... the exact specs are
          8"x17", 20mm
          9"x17", 22mm
          • #95
            8"x17", 20mm
            9"x17", 22mm
            Late reply, but way to aggressive for a mk4, those specs before adding adpater width would be great though!
            Bora gone
            Vento VR6
            MKIV GSW TDI
            7P Touareg TDI
            • #96
              Porsche Boxster Spyder wheels
              Hey Guys,
              Does anyone know whether Porsche's lightest wheels from Sypder will fit on a Golf R??
              Cheers..
              • #97
                Originally posted by reddc5r View Post
                Hey Guys,
                Cheers..
                What are the specs on said wheels? I believe all porshce wheels are 5x130 pcd, and arnt the R's 5x112? in which case no, they wont fit
                BUT Porshce are generally adapter friendly though, so you could try that keeping in mind adapters are illegal of coarse.
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                • #98
                  I'm not sure if the R pcd is 5x112..can someone who knows pls confirm?? Porsche is 5x120 I believe.
                  • #99
                    OK been looking through and searched... will 18X8 WITH A 45+ OFFSET 5/100 fit MK4 GTI
                    Tazz
                    01 Golf GTI
                    95 Golf Cab
                    67 Type3 Fastback (Kermit)
                    62 Type3 Square
                    • Originally posted by Tazz View Post
                      Tazz
                      I had those specs on my bora, was ok until i lowered it on coilovers. i was JUST rubbing on the strut. 5mm spacers fixed it, but even a 3mm would have been ok id imagine. maybe go for something like 8" wide with et35
                      Bora gone
                      Vento VR6
                      MKIV GSW TDI
                      7P Touareg TDI
                      • Thanks Dylan, i do want to try and run without spacers if i can. i will be running coilovers so ET35 looks like the ones.
                        Tazz
                        01 Golf GTI
                        95 Golf Cab
                        62 Type3 Square
                          Tazz
                          if possible, get your coilovers first... And see how low you want to go.
                          Bora gone
                          Vento VR6
                          MKIV GSW TDI
                          7P Touareg TDI
                          • Originally posted by reddc5r View Post
                            Yes i can confirm that the R is 5 x 112. I've been searching for some wheels for my R for some time now and have still been wondering what offsets to go for. Seriously thinking about BBS CH-Rs in 19s and matt black with s/steel lips.
                            | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
                              Porsche is 5 x130 with 14x1.5mm nuts or bolts
                              2010 Golf R 5 dr , Black , DSG , Leather and 8.5x19 ET50 AZEV Type R
                              • Looking for some cool 15's for my VW then some super-low springs not sure what will fit this car, will any 5 x 100 wheels?
                                -Casey
