Hi all,
My coilovers are in and new front sway bar is in. clearance to the drive-shaft finally! My only problem is when the sway bar is on 'lose' (or outer hole) setting, it hits the lower control arm. my mechanic then fitted it at the tighter setting and it only just clears it. it also seems to be worse on the driver side if thats possible...
He suggested getting longer end links, but i was under the impression just the bar solved all the problems...
Anyone else had this problem or has any suggestions?
Cheers, Dylan
Cheers, Dylan
