lowering springs for bora
  • lowering springs for bora
    hey guys
    just wondering if anybody knows where to get lowering springs for a bora v5
    I hve searched but with no luck
    any help would be great
    sigpicThe Mk2 GTI Baby
    I would guess your reputable brands, H&R, Eibach, Neuspeed, Koni would do something for your car. You will probably have to import these though.
    Locally, if you just want it lowered, I believe Kings/Pedders could make some to fit your car. Obviously not in the same league though...
    Look through the mk4 threads and find Bora owners, see what they are running.
    Good luck!
      I believe you'll find parts for the FWD Mk4 Golf will work fine - the V6 4Motion Bora is different (being more like the AWD R32).
      The biggest difference is likely the weight of the V5 engine being slightly higher than the 4-cylinder versions, though the overall effect this has should really be minimal.
      Nothing to see here...
        How much lower do you want to go?
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          Talk to Dubstarv6 he has just done his and its now stealthier than ever
          Jmac
          Alba European
            How low do you want to go?
            White Scirocco R
            White MK3 Golf 2dr
            White Caddy (Work Van)
              Jmac
              I had mine done about a month ago and went for the same setup as DubStarV6 after seeing his setup and him being very happy with the performance - Eibach Pro Kit & Bilstein B8 Shocks
              You can get the springs half price atm here: http://www.eibach.ashop.com.au/p/546917/pro-kit-.html They were delivered to my door within 5 days!
              These are the exact same springs I used. They are for the 10v V5, but still suitable for the 20v..other mk4 golf springs should be ok too, but they are made for a different weight so the fronts could go lower than expected
              Before:
              After
              If you want to go lower then the Sportline Kit will get you up to another 10cm, otherwise go coilovers. Evorobin has Hot Tunings for sale for mk4 @ $800 I think, but that may not be what you are after
              2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
              MY15 Golf Wagon Comfortline
                Stock height
                with sportline springs
                White Scirocco R
                White MK3 Golf 2dr
                  mmmmm...the sportline springs do look sexy...wish I hadnt seen that! lol
                  how much were the sportline springs Silver_Dub?
                  what shocks are you running?
                    I sorced them through a friend of mine who at the time was sponsered by eibach. Now the thing is at the time I could only afford to purchase the springs so I am still running standard shocks, I know everyone will think I'm stupid and Insane which I also think I am. I have been saving to either buy matching shocks or toying weather or not to change to coilovers seen as though I don't drive it much these days. But my biggest problem is I have just brought my first home so funds are a bit tight so it may be a little while before I can do anything. Yes it is a very bumpy ride and it dosn't catch right but of I had the money it would be done tommorow. But I love the height that it sits at, it will take most speed humps without bottoming out but I would like to update to a set of 18" or 19" later on just to fill the guards out a little better later on
                    White Scirocco R
                    White MK3 Golf 2dr
                      I have coilovers in mine, with the 18*8 A8 wheels the front doesnt go any lower then what silver dub's is. If you want to go lower you have to watch wheel width and offset. running my stock wheels at the front with coilovers i can put the car on the ground if i like
                      Bora gone
                      Vento VR6
                      MKIV GSW TDI
                      7P Touareg TDI
                        Hey I just bough a set of Eibach springs, i was wondering if you have any issue fitting your spring with the factory shock and what issue did you come accross after? I know it's crazy doing it this way. but for now i have to do it and i will replace it with new lowered shock. by the way i have 2001 4motion
                        2009 Tiguan TDI and 2007 Passat TDI
