modifying coilovers..... how please?
  • modifying coilovers..... how please?
    i dont know much about this although i have heard about it
    id like to go lower by modifying the coilovers, does anyone know what is involved?
    cheers
    dom
    it would be achieved by extending the thread that gets wound down when lowering the vehicle,then increasing pressure on the spring. Or either cuting half to a coil out of the spring try jdm forum mate.
      whoar! dont know about cutting a coil out! and also the tread on the coilovers stick out more than the shaft itself so i cant exactly make a extended thread because there isnt any metal to cut into
      could there be an option to get custom springs made up?
      dom
        can you remove the helper spring at all??
          dom
          Yes I don't see why not, coilovers are made with the strut and coil . By what I mean by thta they are made especially for eachother, I don't see why not you can't take it to a spring place and get new coils made up with the same spring rate just a smaller spring
            i dont wanna remove or cut anything, i would like a complete shocker/spring setup, just modified for more height adjustment
            dom
              New spring quickest and cheapest way to do, and if you want to lower sell them just put the old springs in there.
                dom
                ? dude that means buying different coilovers...
                just remove the small spring at the bottom... that way you get another inch of adjustment
                its not doing anything now in your car because when the car is on the ground its fully compressed...so its just taking up ride height.
                Stu
                  *cough* airstruts! *cough*
                    i am with Jarred
                    Velly
                    '91 2.0 8v GTI
                      Stu
                      yeah your right, i went past a springworks place, he said the same thing, plus apparently the spring is around a 500kg one whereas he was reccomending a 280kg one
                      he said for me to try taking the catching spring out, as all it is there for is to hold the main spring in place while its off the ground, said it will drop another inch or so haha!
                      after this mission ill be almost touching cloth....
                      dom
                        If you wind em right down, and remove the helper spring, you'll def get another 1"-2" I reckon. won't be able to run no wide lips though...
                          they are wound all the way down.... you were here when we did it hahaha!
                          as for airride, thats out of the question untill a bag full of cash gets shoved into my face.... preferably over 10k would see airride happen...
                          dom
                            Yep, just remove helper springs. They're only there to keep the spring seated when jacking up the car. At my height, my helper springs don't do their job as the distance from the top spring seat to the adjustment collar exceeds the length of the main spring and helper spring hahaha. Just make sure when you lower it down back to earth again, you do it slowly and make sure the main spring seats properly.
                            Present: Mk3 Golf variant.
                              won't you still have the issue of bottoming out your struts? You might have to run shorter struts and shorten your shock bodies.. I'm not sure without having a look.. But you might want to watch out for that.
                              You're going to have to dry sump the damn thing if you go any lower! Haha.
