When I bought my GTI second hand with about 86,000km on it, it was in excellent condition, and it was clearly very well looked after. I wanted to continue the trend, so I decided to give my suspension a 100,000km complete refresh. The car still feels tight, it still handles well, but if I'm going to keep the car for another 100,000km, I thought I may as well keep on top of the suspension rather than letting it slowly deteriorate.
When deciding what I wanted, I wanted comfort primarily, but I also wanted to lower the car a bit whilst retaining that OEM ride quality feel. After hours upon hours of research it seemed like Drivers Gear springs and shocks from Volkswagen were the go, but unfortunately all Drivers Gear products are discontinued and are now unavailable. The Eibach Prokit setup seemed like the next best option, but something didn't sit right with me in regards to how firm the ride would be. H&R was completely out of the equation. So I started looking at the RacingLine range of gear and the main point that attracted me to them was the fact you could use the springs with the OEM struts and there would be no negative effects, which signals to me that everything about them should be OEM like and the 20mm drop they advertise wasn't too low for me either, as I value practicality and actually being able to go up and down driveways.
I looked into obtaining the RacingLine spring and strut set from Australia as I strongly believe in supporting local business but to my dismay I found the primary importer of RacingLine gear was Harding Performance. Knowing Guy Harding's previous history I was extremely weary about purchasing from him, so I didn't. I did enquire with them, but a few of their responses regarding what they had in stock didn't sit well with me in comparison to information I received directly from the manufacturer. I sourced these springs and shocks from Progressive Parts in the UK, who were absolutely fantastic, helpful and efficient. Highly recommended. I pick the combo up for around AU$960 shipped, which was a $500 saving from buying from Harding Performance. Looking at the kit, everything was packed extremely well, no shortage of bubble wrap and protective cardboard. The springs and shocks felt solid, looked solid and there were no obvious faults in the painting, welding or anything like that.
Seeing as I was replacing the suspension, through research I found that the front and rear strut tops, bearings and supporting bolts and nuts should also be replaced. I sourced some Audi TT strut tops, with a full set of replacement nuts and bolts for everything that gets touched on the front end from FCP Euro. Once again, I tried to buy these parts locally, but I called a few part shops, Audi dealers, no one was really happy to quote so many parts, or just never got back to me. The FCP Euro site is so easy to use, you put in any part number and they magically appear. I also tried getting a quote from VAGPARTS AustraliaRTS Australia but never received a response to my enquiry. As you can see from the parts list, it's a very comprehensive list of replacement parts, and perhaps not every single nut and bolt needed to be replaced, but I did not want to compromise at all. I didn't want bangs, noises, rubbing. I just wanted everything to work the first time. All this came to AUD$321.
As I was going this far, I decided it would be worth getting an anti-lift kit as well installed, Sparesboxox had a New Years special on and I managed to snag a SuperPro ALK for $219. The quality of this unit is absolutely beautiful and it's a shame that it's going under the car.
This is all getting installed on Monday at Volkwerkekwerke as well as 4 new Michelin Pilot Sport 4s ($220 each fitted and balanced) from Bob Jane T-Marts (Official). I refused to support the grey import scene, and I'm paying the extra for them to source and install the tyres rather than supporting companies that go through back doors like Tempe Tyre & Wheel Centre and other grey importers. The car will also be getting a front and rear alignment done at TruTrack Suspension in North Melbourne.
I'll post my feedback once I get the car back and go for a spin.
Images of all the gear below -
