I've just been doing a bit of a test fit with my track rims now that I'm going to run 215's up front on my 9N3 Polo gti. If I run my 15mm spacers that I was using with my 205's, I end up with a 12.5mm drill bits clearance between the tyre sidewall and the coil over body. I do need to move the rim inboard as the tyres are sitting wide of the fender so I need to do something. I've calculated that if I go to say an 8mm spacer I should have about 5mm clearance against the strut. Is that too close? I think with low profile tyres I'd be ok but I'm on 215/50/15 on the track that will have a bit of sidewall deflection. safe?
sam
sam
