So, I have just installed my RNS510 in my 2013 Caravelle. It was an easy swap, but I am having some troubles figuring out the coding. The radio works fine, the SD card and HDD are fine. My vehicle had bluetooth, but it isn't recognising it now. The Navigation isn't working at all, but I am waiting on my map DVD to arrive, so not too worried yet. I haven't got the steering wheel controls to work properly yet either. I tried loading the firmware via CD (version 528x, or whatever the link was...) but it failed 3 times with different CD's. I am going to try a DVD later on. My current software version is 0972, should I just leave this? Hardware version H60. where should I be starting with this? I am a beginner with VCDS, but happy to learn, so if you can let me know where I need to look, that would be great!
Below are the scan results after the install:
Thursday,19,October,2017,17:57:31:18063
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
Ross-Tech: Home
Chassis Type: 6N0
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 4B 56 69 77 0B
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
4B-Multifunc. Module -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H32 0407
Revision: BO032001
Coding: 842300
Shop #: WSC 02756 790 12345
VCID: 70BAD8219AA77B77ABA-8024
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Time Indication: 0
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Time Indication: 0
03590 - Control Module for Multifunction Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Time Indication: 0
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 685 HW: 3C8 035 685
Component: RNS-MID H60 0976
Revision: B001001 Serial number: VWZ6Z7M9087040
Coding: 00010440020000A30014
Shop #: WSC 00040 040 00001
VCID: 698CB545B97D8ABFEC4-803C
5 Faults Found:
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
00872 - Bass Speaker Rear Left (R15)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 32
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
00869 - Line Output; Rear Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
00860 - Line-Output; Rear Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
Address 4B: Multifunc. Module
Cannot be reached
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 32
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664101250
Coding: 0A01020000010101
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 392C250589DDFA3F5C4-806C
2 Faults Found:
9457171 - Right audio channel for speech/telephone
B104E 13 [008] - Short to GND
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 145
Mileage: 125110 km
Date: 2053.14.27
Time: 10:48:25
9458195 - Control Module for Cellular Telephone
B1052 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 242
Reset counter: 146
Mileage: 123443 km
Date: 2053.14.00
Time: 17:25:36
Ross-Tech: Home
Chassis Type: 6N0
Revision: BO032001
Coding: 842300
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Time Indication: 0
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 32
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
Cannot be reached
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 145
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 32
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 16
Reset counter: 106
Mileage: 125104 km
Time Indication: 0
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 145
Mileage: 125110 km
Date: 2053.14.27
Time: 10:48:25
Freeze Frame:
Fault Priority: 4
Reset counter: 146
Mileage: 123443 km
Date: 2053.14.00
Time: 17:25:36
