As title suggested, I am doing an audio system upgrade on my Passat B8 132tsi comfortline with discovery pro 8 unit. I will be installing:
- Helix P Six amp/dsp combo
- Focal PS165FX for fronts going active
- A subwoofer in the trunk (DB1212)
Since my amp has both rca and high-level input, which one do I use to connect from the head unit? Do I need to do VCDS coding on the head unit? If I do, which options should I choose?
Thank you!
Thank you!
