Headlight Electrics - Fixiable or not???
Hmm not sure....perhaps an electrical guru can advise. If you do need a replacement headlight, i have a pair that i removed from my Mk6 GTI about 6-8 months ago to fit xenons. Happy to sell either 1 or both of them too for cheap if you need them.
They are replicas of the optional VW units. Made by a company called Eagle Eyes in Malaysia and im using a Morimoto xenon ballast/bulb etc.
The light output, while much better than the original halogen headlights - is not as good as the genuine xenons. If i end up keeing the car much longer i may look at replacing the projector lenses with a better quality (Morimoto or similar) unit to make them better. But the actual lenses and housings etc are very good....certainly better than others i have seen.
I sourced mine through a place in Syd called VCDS Coding & Diagnostics Sydney (look for them on Facebook).
Pics here: http://www.vwwatercooled.com/forums/...ml#post1194957
