T10 LED Parker issues
  • T10 LED Parker issues
    Hey Guys,
    can one help me with T10 LED parker conversion in an R36?
    this is the 3rd set i have bought and none of them are working and they are supposed to be CANBUS... its not the fuse as putting a standard filament globe back in works.
    i have checked for polarity by turning them, that obviously didn't work. and put them in my forester and they all work no issues.
    EUROTRASH
    Have you tried them inside the headlight or just wires hanging outside ?
    Sent from my SM-G935F using Tapatalk
      Are you getting bulb errors with them installed?
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        i fail to see how that has anything to do with it. there is no interlock on the cap. and the normal globes work outside the housing too.
        EUROTRASH
          yes still getting errors.
          EUROTRASH
            is there a way to test if the bulbs are actually CANBUS?
            maybe i've been getting duped by unethical sellers and buying products that aren't actually CANBUS
            EUROTRASH
              When you're changing polarity, are you cycling the key and the headlight switch to clear the errors?
              '01 Beetle 2.0
                By cycling the key you mean taking the key out then turning the bulb around then putting the key back in? Then yes. Even trying it with the key out and cycling the switch.
                The original ones can on then went out after 5 seconds or so but these ones don't come on at all.
                EUROTRASH
                  Dont buy ebay LED's. If you want good quality LED's that work in VW's without giving errors, look at Bold Sport bold-sport
                  B9 Audi SQ5
                    These do not appear to be CANBUS compatible.
                    CANBUS compatible simply means the units have resistors on them, to simulate the larger power draw of a conventional globe.
                    You'll be able to tell, as a real CANBUS compatible globe will also be covered in heatsinks; and look a lot different.
                    LED globes have a certain polarity, too - make sure you have them the right way around. (If they work; they're the right way around)
                    I have LED indicators in my Octavia's headlights; and LED reverse lights in the tail lights. My tail lights are also aftermarket fully LED units and work perfectly, and do not produce errors - but that being said; they have huge resistors on them to trick the car into thinking that its still running the incandescents.
                    Please see the below image; you can easily see how much more "substantial" the globe looks, because of all the added heatsinks (for heat dissipation)
                    This is what you will need.
                    Not including hers...
                      hey Lucas_ R you don't happen to frequent carrington do you?
                      BTW this Bold-sport is uber expensive seeing as though they look almost identical to the ones i already have
                      EUROTRASH
                        I both live and work not too far away so you might see me near Carrington occasionally (White Mk6 GTI with grey 5 spoke rims).
                        And yes i agree the Bold Sport LED's are expensive, but they are good quality and they work.
                        B9 Audi SQ5
                          Ah nah wasn't you then... I thought you might of had that R in your avatar as well as your gti...
                          I wouldnt mind getting your needling on start up upgrade in my passat... Can you help me out?
                          EUROTRASH
                            That Golf R now resides in Tasmania with its new owner - sold it nearly 2 years ago to put money towards house renovations and bought a cheaper GTI 2nd hand. Loved the R but it sat in the garage most of the time.
                            I wasnt aware the Passat R36 was able to have the needle sweep activated.....are you sure it can? Even with the Mk6 GTI, only some of them can support the needle sweep as it has to do with which revision/part number the instrument cluster is. Luckily i was able to activate the needle sweep in my GTI.
                            I'll do some research on activating this for the R36 and see if its possible. If so, then yes i can help.
                            B9 Audi SQ5
