Hey all,
Ive had a bit of browse through the net and the forums for a thread with the information im after, but for the life of me I cant manage to find majority of the answers im looking for, so I thought i would ask them here in one spot.
So I recently bought a MY12.5 Polo 77tsi and so far the experience ive had with the bluetooth audio is nothing short of terrible. As far as i can tell, the phone connects to the Touch Adaptor through bluetooth, which then connects to the RCD310 through the same process. Problem is, it sounds like complete rubbish.
I have an AUX in line right there, but Id rather my car not be a mess of cables from the aux + charger.
I have the touch adaptor with the RCD 310 Headunit.
What i want to do is install either the RCD or RNS 510 headunits instead.
My questions are:
1) So far, the only difference I can find between the RCD and RNS 510 are RNS having sat nav. Is that the only difference? Also, how is the map quality on the RNS 510 and are they quick to find your location ? Im finding it a bit hard to justify spending an extra $300-$450 for just navigational extras, but if the quality is exceptional it would sway me a bit.
2) Will I need a GPS module for the RNS 510 ? Ive read that if you have a shark fin antenna it isn't required, but there's my problem: My antenna looks like a shark fin, but still ends with about 15cm of antenna.
3) After changing them, will I need to also install a bluetooth module for either HU (Headunit) ? Some people are saying its needed for only the RCD but that the RNS already has bluetooth integrated, but Id rather not buy the headunit then realise my bluetooth doesn't work and having to pull it out all over again.
4) In the end, I want to install a mono amp running a decent sub; I havent seen any RCA inputs in the headunits but Ive seen people running subs off of the stock HUs. Is there an adaptor out there for them?
Thanks in advance,
Ibby
My questions are:
Thanks in advance,
Ibby
