The Tig is actually my wife's car which I take out on the odd occasion (VWW cruises mostly). She just wants the digital speedo in the display and to be able to set speed alerts. Unless anyone can come up with something more by the end of the weekend it looks like I might just fit the old Mk6 wheel back in until we get some more info. At least that way she'll have working buttons during the week.
Installation of a Mk7 Multi-Function steering wheel + paddles into a Mk6
Originally posted by marcrae19 View PostHow frustrating Tigger. I say you wait as well.
@James - there is a chance i will be in Canberra next Sunday - maybe saturday afternoon/evening as well. How long would something like this take ? alternatively i could leave my MK7 MFSW wheel with you.
Not sure if tigger can wait that long though!
@marcrae19 - I'm not sure what I'm up to next weekend, but if you've got the steering wheel installed in the car then it'd probably take about an hour to access the CAN Gateway, hook up some diagnostic kit and log what happens when you operate the buttons. It'll take less time if you have already physically accessed your Gateway for some reason in the past, as it means fewer cables / relays to move out of the way first.
Without the wheel installed in the car we can't check what's happening between the wheel and the controller which is the key to figuring out the next step.
@tigger73 - I've got the Mk6 electrical current flow diagrams on my server at home somewhere - I'll take a look if I get a chance over the weekend and see if there's a pin layout for the MFSW connectors.
That would be the best.Originally posted by jamesatfish View PostI've got the Mk6 electrical current flow diagrams on my server at home somewhere.- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
Well I found a thread over on vwvortex with the mk6 steering wheel pinout and it's kind of making a little bit of sense now.
So for the yellow connector (F350), pinout as follows:
Pin 3: Airbag
Pin 4: Airbag
Pin 7: Ground
Pin 8: Horn
Pin 9: Lin bus
Pin 10: 12V
For the black connector (J453):
Pin1: GND
Pin2: 12V
Pin3: Lin
Pin4: Horn (in)
Pin5: Horn (out)
The horn signal looks like it may go via Lin as well as its own signal.
Now all I need is the pinout for the Mk7 Steering wheel control unit (black connector) and I should be able to get this sorted....Last edited by tigger73; 29-08-2015, 02:11 PM.
Nice find!- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
After trying a number of different wiring options today, I've gone back to the standard Mk6 wiring (with the horn routed through the black connector rather than going direct to the yellow one).
I've come to the conclusion that the wiring is not the issue. The paddle shifters are working fine and these have to come through the LIN bus so there has to be comms working. Also the fact that a few of the buttons actually do some stuff means that there;s no real problem with the hardware.
So that leaves me either with the fact that there's a VCDS setting that I'm missing, there's incompatibility with the Mk7 buttons/LIN messages and the Mk6 SWCM or there's something else I've overlooked.
So I've come full circle and ended up back at the same place as the start of the day. However I do understand a little bit more and have managed to cross a few things off the list at least.
Having a think on it overnight it may be that the simplest way of getting this steering wheel going is to replace the buttons/controller with ones from the latest Scirocco - which has the same look as the Mk7 but has the buttons from the Mk6.
My hope is that these buttons would fit into my new Mk7 wheel.
The risk with these sorts of retrofits is always compatibility of hardware. Without some equipment to decode the LIN signals to determine what button press causes what message in both mk6 and mk7 button controllers (module in the steering wheel that generates the LIN messages), it's a little bit of guess work. I now suspect that the people that have this working either have a newer version of SWCM or have somehow jagged a Mk7 steering wheel that is backwards compatible with the Mk6 SWCM hardware.
For others reference the hardware I have in the Tiguan is a highline module. Scan details as follows:
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LGB0001F
Coding: 1892140000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76CD31ABC973E38E7F-8023Last edited by tigger73; 30-08-2015, 09:10 AM.
Tigger - matt from vagnostics in the UK has everything working bar illumination. I'm talking to him at the moment to see what type of cost would be involved to get the required harness / wiring and support to put ours in.
I wonder if there is a way to provide constant illumination? I drive with my lights on during the day so it wouldn't bother me.
I seriously don't think the problem is the mk7 wiring harness. I've tried about every single wiring combination possible and have come to the conclusion that the mk7 wiring harness would work as-is. Though I ended up leaving it modified to the same pin-out as the Mk6.
What is going to be of most value now is to find out what the part# for the mk6 SWCM and also for the Mk7 button controller that the guys in the UK are using.
I'm not too concerned about illumination right now. Car mostly gets used during the day anyway.
Sent from my iPhone using TapatalkLast edited by tigger73; 30-08-2015, 10:24 AM.
Here was the response from the german dude who made the converter for Oem-plus-tuning. He also has a website bronken . de
It has nothing to do with the cable. The LIN Identifiers on the Databus are all different between PQ and MQB and no wire in this universe can change that. The 100% solution would be a lin to lin converter. But my module was lin to can and the lin/lin would be a complete new development. Possible yes. But not existing atm. It would take several months to develop.Last edited by marcrae19; 30-08-2015, 10:22 AM.
Makes sense that he got the Scirocco wheel to work as its a mk6 platform vehicle.Originally posted by marcrae19 View PostScratch that. Matt actually has installed the sirocco wheel. He also installed our wheel but without cruise control.
Can you ask Matt what the SWCM that he's used to work with the true Mk7 wheel. I suspect this may be my problem even though mine is a highline module suitable for a MFSW.
That confirms my suspicions. But then I'm confused as to how others with supposedly Mk7 wheels with the cruise on the wheel have got theirs to work. I'm guessing there must be some versions of the Mk7 style wheel that are PQ and others that are MQB even though they may look identical.Originally posted by marcrae19 View PostHere was the response from the german dude who made the converter for Oem-plus-tuning. He also has a website bronken . de
Well perhaps these guys are getting the steering wheel from the latest Polo GTI. This is a PQ25 based car and not MQB, though they do look identical from the outside:
Although it looks the same I now believe this is the steering wheel that the guys in the UK will be using. It makes sense that everything but the cruise control works as likely the SWCM doesn't understand the LIN signals for the cruise control buttons so just ignores them.
So in summary a steering wheel out of an MQB car will not work in a PQ platform vehicle (and vice versa). There are a number of Mk7 "look-a-like" wheels out there (Scirocco/Polo) and you'll need to get one of these if you want to retro-fit into a Mk6.
I'm going to reconsider my options now. As I see it I can either sell the wheel I've got and start again, look to get some buttons to retrofit into my current wheel or develop a LIN-LIN converter to change the signals from MQB to PQ platform.
Though I think I might just put the old steering wheel back on for now while I consider my options.Last edited by tigger73; 30-08-2015, 11:44 AM.
Could be the case, although I'm sure some of the guys referenced Golf R.
@james - making a Lin / Lin converter. Is that something you do or would be interested in doing? Would you agree that this is the only way forward when trying to put the MQB based wheel into PQ / BCM ?
