RNS 510 problem
  • RNS 510 problem
    Hi guys
    I fitted a RNS 510 V H to my 2011 Multivan a few months ago and it seem to work fine but i wasn't really using it much. I then fitted a 9W7 Bluetooth module and coded it(not sure the coding is right).
    The sat nav keeps freezing up or seems to not be in the right place when driving. I have noticed when I play off the SD card it sometimes skips tracks as well.
    I will post a copy of scan with error codes.
    HW-Version H61
    SW-Version 5238
    Map V 8036
    Please help this is driving me mad.
    Frans
    2011 T5 Mulitivan Comfortline 103kw ,2009 Golf Tdi Comfortline 103kw,2005 Golf Mk5 GTI Stage 1 220BHP (UK),2004 Golf GT TDI 140BHP (UK),1995 Golf Mk3 GTI 120BHP (UK), 1980 Escort Mk2 RS2000(South African), 1980 Opel GTE 148Kw (South African), 1979 Golf Mk1.
    It sounds like an incompatibility issue with your 9W7 and the firmware that is on the unit. Since you are located in Melbourne, feel free to come by our workshop which can be found at: vwcentral
    I will check your coding on the BT module to eliminate that from the equation.
    Best Regards,
    Dean
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
      Hi Dean
      When would it be best to stop off at your workshop?
      Frans
        Looks like we got this one sorted Fransnz! If it plays up again, i'm going to blame the hard drive.
        Did you have any luck re-positioning the GPS antenna to see if it responded faster to your current positioning?
          Hi Dean
          I changed the aerial and check the harness and still have the same problem. I think you right and it must be the hard drive. Not sure what to do about changing it.
          Was going to see if I could find the original firmware version and downgrade to see if it makes it better. Do you know what it would have been?
            Hi mate! If this is the RNS510 you bought from me in April, these are the details:
            Originally purchased new from lithuanian ebay seller "and_jur". It is a RNS510 "H" version, build date December 2012. Part number 1T0 035 680 H, Hardware version HW H61.
            Software version on the sticker is 2760 BUT the software version on the unit when I first bought it was actually 3970, see here:
            Note the screenshot says hardware version "F" even though it's a "H" I was told on this forum that that is because the firmware only went up to maximum "F" but if VCDS says it's a "H" then that is the true version in VCDS.
            This is a VCDS scan from the Tig when I had this radio installed:
            Code:
            Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
               Part No SW: 1T0 035 680 F    HW: 1T0 035 680 H
               Component: RNS-MID       H61 3970
               Revision: AB001001    Serial number: VWZ6Z7L9365009
               Coding: 00000440010000A00009
               Shop #: WSC 00229 211 17803
               VCID: 3169AFA9687168B2B4-8064
            No fault code found.
            I never had any trouble with this unit, had it for 2 years, and would be surprised if it's a broken hard drive?? Have installed tons of these in friends cars, including old C version (pre LED) and D versions, they are all going strong... (OK not tons, but have installed more than 10 for sure, it's so easy and only takes 10 seconds On one occasion after 1 year I had a case where someone's GPS played up and it was a case of broken GPS antenna - in fact the problem was at the back of the radio, when it was pushed in the GPS wire got bent at a 90' degree angle and got squashed - anyway a new GPS antenna from China eBay $18 and that one was fixed good as new.
            Having said that I would suggest
            a) Yes put a copy of FW 3970 there and see what happens? If it still persists then.....
            b) Disconnect the 9w7 and drive around for a few weeks, see if that's the problem?
            c) Maybe post up a full VCDS scan so we can see what the errors are you say?
            I would be curious to know of any of the experts or regulars here have seen anything like this before, kamold, johnc, aussietig etc you guys would know best
            - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
            - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
              Hi mate here is a full scan from that car from 2014 that I had backed up showing all the coding for radio, nav and phone, maybe it can help?
              FIRST HALF:
              Code:
              Wednesday,16,July,2014,15:17:21:22578
              VCDS -- Windows Based VAG/VAS Emulator
              VCDS Version: 14.6.0.0
              Data version: 20140601
              VIN: WVGZZZ5NZ8W047226
              Mileage: 72887   Repair Order: Premium_COL_Clustr_installed_successfully
              Chassis Type: 5N (1K0)
              Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 53 56 62 72
                        77
              VIN: WVGZZZ5NZ8W047226   Mileage: 72887km
              01-Engine -- Status: OK 0000
              02-Auto Trans -- Status: OK 0000
              03-ABS Brakes -- Status: OK 0000
              04-Steering Angle -- Status: OK 0000
              08-Auto HVAC -- Status: OK 0000
              09-Cent. Elect. -- Status: OK 0000
              15-Airbags -- Status: OK 0000
              16-Steering wheel -- Status: OK 0000
              17-Instruments -- Status: OK 0000
              19-CAN Gateway -- Status: OK 0000
              22-AWD -- Status: OK 0000
              25-Immobilizer -- Status: OK 0000
              37-Navigation -- Status: OK 0000
              42-Door Elect, Driver -- Status: OK 0000
              44-Steering Assist -- Status: OK 0000
              46-Central Conv. -- Status: OK 0000
              52-Door Elect, Pass. -- Status: OK 0000
              53-Parking Brake -- Status: OK 0000
              56-Radio -- Status: OK 0000
              62-Door, Rear Left -- Status: OK 0000
              72-Door, Rear Right -- Status: OK 0000
              77-Telephone -- Status: OK 0000
              Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
                 Part No SW: 03L 906 022 AA    HW: 03L 906 022 G
                 Component: R4 2,0L EDC G000AG  1998
                 Revision: --H01---    Serial number: VWX7Z0H33NE115
                 Coding: 0000175
                 Shop #: WSC 83968 930 682118
                 VCID: 64C716FDA7038D1A8F-8031
              Readiness: 0 0 0 0 0
              Address 02: Auto Trans        Labels: 09G-927-750.lbl
                 Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
                 Component: AQ 250 6F           1124
                 Revision: 00H76000    Serial number:
                 Coding: 0000328
                 Shop #: WSC 01324 785 00200
                 VCID: 78FF528D0B8B79FA33-802D
              Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
                 Part No SW: 5N0 614 517 K    HW: 5N0 614 517 K
                 Component: J104    C2 450 V1   0006
                 Revision: --H11---    Serial number: 00000001024357
                 Coding: 0006434
                 VCID: 36639CB5411F4F8AE1-8063
              Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
                 Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
                 Component: Climatic PQ35   142 1111
                 Revision: 00142031    Serial number: 00000000000000
                 Shop #: WSC 00000 000 00000
                 VCID: 76E35CB5019F0F8A21-8023
              Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
                 Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
                 Component: Bordnetz-SG     H54 2202
                 Revision: 00H54000    Serial number: 01000008240707
                 Coding: A4880B8300041C0047190000140000000009004064800114390000000000
                 VCID: 6FED69D17EC53E42E2-803A
                 Subsystem 1 - Part No: 5N2 955 119   Labels: 1KX-955-119.CLB
                 Component: Wischer 250308  012 0203
                 Coding: 00038805
                 Shop #: WSC 01324
              Address 15: Airbags        Labels: 5N0-959-655.lbl
                 Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
                 Component: J234__202 VW10 HI   1815
                 Revision: 19013000    Serial number: 0039DP6KDB3H
                 Coding: 0012338
                 VCID: 3B758D817A3D92E21E-806E
                 Subsystem 1 - Serial number: 6333FTS634260798
                 Subsystem 2 - Serial number: 6343FTS651540788
                 Subsystem 3 - Serial number: 6353ETS6CDHVSVNH
                 Subsystem 4 - Serial number: 6363ETS61C6TSVNP
                 Subsystem 5 - Serial number: 00000000000000000
                 Subsystem 6 - Serial number: 00000000000000000
              Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
                 Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
                 Component: J0527           056 0111
                 Coding: 0001632
                 VCID: 7AFB488535876BEA45-802F
                 Subsystem 1 - Part No: 5K0 959 542 B  Labels: 3C8-959-537.CLB
                 Component: E221__MFL-TAS   H30 0036
                 Coding: 00000131
                 Shop #: WSC 00000
              Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
                 Part No SW: 5N0 920 882 C    HW: 5N0 920 882 C
                 Component: KOMBI         H03 0407
                 Coding: 110E00
                 Shop #: WSC 01324 020 00200
                 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
                 ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
                 VCID: 3365A5A19A6D5AA2C6-8066
                Second half (VWWatercooled only lets me post 10000 characters at once?)
                Code:
                Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
                   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
                   Component: J533  Gateway   H07 0052
                   Revision:   H07 01    Serial number: 070408F1003730
                   Coding: FD827F064006026003
                   VCID: 306FAAADA37B61BABB-8065
                Address 22: AWD        Labels: None
                   Part No SW: 0AY 907 554 B    HW: 0AY 907 554 B
                   Component: Haldex 4Motion      0039
                   Coding: 0000005
                   VCID: 4A9BD84525E73B6A95-801F
                Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
                   Part No SW: 5K0 953 234     HW: 5K0 953 234
                   Component: IMMO          H03 0407
                   Coding: 000000
                   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
                   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
                   VCID: 6ADB78C58D27DB6AB5-803F
                Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
                   Part No SW: 5N0 959 701     HW: 5N0 959 701
                   Component: Tuer-SG         006 1206
                   Coding: 0000758
                   VCID: 72EB60A56DF713AA0D-8027
                Address 44: Steering Assist        Labels: None
                   Part No: 5N2 909 144 A
                   Component: EPS_ZFLS Kl.163 H08 1902
                   VCID: 3169AFA9A87168B2B4-8064
                Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
                   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
                   Component:    KSG PQ35 G2  020 0205
                   Revision: 00020000    Serial number: 00000000000000
                   Coding: 9A800A0052834C3F3F04840560089F0B80F940
                   VCID: 03053561424D2A2216-8056
                   Subsystem 1 - Component:   Sounder n.mounted
                   Subsystem 2 - Component:       NGS n.mounted
                   Subsystem 3 - Component:      IRUE n.mounted
                Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
                   Part No SW: 5N0 959 702     HW: 5N0 959 702
                   Coding: 0000758
                   VCID: 73E565A112ED1AA206-8026
                Address 53: Parking Brake        Labels: 5N0-907-801.clb
                   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
                   Component: J540 EPB3  VW-09384 0005
                   Revision:   H08       Serial number: 00000000054219
                   Coding: 0000057
                   VCID: 2E53B4D5B94F774AA9-807B
                Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
                Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
                   Part No SW: 5N0 959 703     HW: 5N0 959 703
                   Component: Tuer-SG         006 1301
                   Coding: 0000208
                   Shop #: WSC 01324 785 1012551
                   VCID: 74E766BD17E31D9A1F-8021
                Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
                   Part No SW: 5N0 959 704     HW: 5N0 959 704
                   Coding: 0000208
                   VCID: 75E15BB91C99049228-8020
                Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
                   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
                   Component: TELEFON       H15 3200
                   Revision: 1B001001    Serial number: 00007662931648
                   Coding: 0010000000010110
                   Shop #: WSC 12345 123 12345
                   ASAM Dataset: EV_UHVNA 002720
                   ROD: EV_UHVNA.rod
                   VCID: 3A7B8885BD07ABEA05-806F
                End
                  Thanks for the copy. Will check it against what i currently have.
                  Do you a scan on your current van?
                    Still having the same problem and have read up the about disonnecting the compass sensor as it maybe messing with the sat nav.
                    Has anyone ever heard of this before?
                      I am still having ongoing problems with my rns510. I have fitted the 9w7 version P to the rns 510 H. Do you think there could be a compatibility problem.
                      Going to try unplug the unit and try it out.
                      Thank you
