RNS510 with Fiscon Kufatec Bluetooth but no working microphone
  • RNS510 with Fiscon Kufatec Bluetooth but no working microphone
    Hi,
    Have had a Mk6 GTI for over a year now which came with Fiscon Kufatec Bluetooth unit installed. It was working fine the last year and all of a sudden it stopped working. The car has been sitting dormant for over a week and perhaps was low on battery but don't think that would have contributed to this.
    Anyone know who could have a look to get this fixed (Sydney based) or thoughts on how to address this issue?
    Can you find the control module. If so dsconnect it and reconnect. See if it works then mate.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
      ^^^this.
      Try and start your search by looking under the driver's seat. After that, try passenger's seat, and finally.....if not there, it'll be 'hidden' behind the dash/Head Unit.
        Nothing under drivers or passenger. will have to suck up the courage to take out the head unit, nail biting for a noob like me!
          Nothing to it, mate — a 5 minute job.
          With small screwdriver or other suitable device, prise out the RNS510 surround — it’s all on clips — and remove the 4 Torx 20 screws holding the head unit, which will now slide out far enough to allow hand access.
          There's plenty of slack on the wiring to let you work behind the unit.
            Awesome. Will give it a crack first, was fearing once taken out there would be other issues. Thanks everyone for your help!
              old credit card etc is also handy to remove the trim surrounding the head unit
                Ok. Thanks for all the advice. It's worked! Used an old plastic trimming tool I had from an old car seat cover set to pry open the cover and low and behold the Bluetooth unit was hidden behind the head unit. Disconnected the plug and reconnected again to the Bluetooth control unit . Then just had to pair the phone again and it works! Very please with myself and thankful for the help. Cheers!
                  [/IMG]
                    Good work mate! If it keeps happening hit me up for a vw 9w7 BT kit!
                      @darkhorse Haha sure no worries.
                        9W7 and 9WZ.....awesome bits of kit.
                        Good work on finding the Kufatec unit and reporting back so quickly. Others will be thankful to see this result when they experience similar problems, and will have confidence that it is a job they can tackle themselves.
                          Good to know and thanks. I updated the firmware on my Fiscon Kufatec Plus this past weekend. Originally it was running Mainboard 1.73 and PBoard 1.83 and after updating it changed to Mainboard 1.73 and PBoard 3.12.
                          However, I still cannot wait to replace it. Two key things are the insistence on the phone to interrupt whatever is happening on the screen (soundwise) whenever anything happens on the phone - so message of any sort, email etc, and everything gets paused. No sound is played - just pausing as the phone symbol comes up on the display, then after about 3 seconds it starts again (although it used to be a longer before I updated the firmware). On some occasions it does not receiver from this and you have to resort to turning off Bluetooth on the phone to allow sound to commence again, which will only happen when the car is restarted so that it goes into pairing mode..
                          Secondly, it only allows Bluetooth music streaming through the front speakers which takes me back to the 1980's.
                          Most definitely time for an upgrade me thinks...
                          2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
                          2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
