2005 Multivan Options
  • 2005 Multivan Options
    Looking at a head unit that will fit a 2005 model
    It currently has nothing, what will actually fit in after market brands?
    You need an adaptor plate/facia plate and wiring. Then pretty much everything fits, single or double din! It's up to you! (even one of those Android based NAV units might be worth a look).
    It's early and I've done a quick a dirty search for parts so wont guarantee they are the right ones, but something to start off your search in any case :
    The unit in newer cars is a double din hole, you just need the right trim pieces to fill around it like this:
    Pioneer Double-DIN Installation Kit for VW T5 Multivan: Amazon.co.uk: Electronics
    Mind you in the case of the multi it looks like it actually adds in the internal frame too... in either case there is a kit for that.
    This leaves you with the option for any double or single din radio ever made.
    A quick and dirty search showed this:
    Amazon.com : Stereo Wire Harness VW Jetta Double Din 02 2002 Car Radio Wiring Installation Parts : Vehicle Wiring Harnesses : Car Electronics
      Thanks for that
      What is the can bus or whatever its called ? Is that just for later models or does it effect a 2005 one?
