Originally posted by kamold
View Post
I didn't mention the 'line out from RNS510' thing so as not to complicate matters. It requires another bit of wiring (RCA adapters, though they're cheap) and changing the setting in VCDS (easy if you have access to that).
I wonder though if doing it that way would give better quality than using the speaker level output? Using the speaker level output you would have the factory equalisation (presumably with good speakers and an amp not desirable), but does low level output do away with that equalisation? Or is it still there and you need a processor to get rid of it (or correct it)?
That was one thing I was going to test when installing mine, but it's so much easier to wire up for speaker level output I don't know if I'll bother testing line level output.
It is just easier to get an amp that can accept speaker level input. Seems a common feature now.
Also interesting to see how far the factory speakers can go with an amp added. It'd be interesting to know their specs.
