My R36 is complaining to me to "check tyre pressure". I have checked and sure enough it's fine. I'm guessing one of the sensors have died - is there a way that I can check to see which one is returning a faulty value?
Tyre Pressure Monitoring
If you've checked all your tyres and the pressure is what you want, reset the TPMS by holding down the button for 3 seconds. It will then start monitoring from the current pressures.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi mate,
I know with mine that it said the same thing. There was nothing wrong, but I went to the servo and pumped them up to 40psi and the warning went away. I have heard that it is at about the 39psi mark it starts to worry but I also think that it depends on what mode you have it in also. Mine is set at moderately loaded as opposed to whatever the minimum setting is.2013 Touareg V8TDi - Black, LED Interior Mods, LED Projector "VW" Door Courtesy Lights, 20" VW Mountain Rims with A/T Tyres, Pioneer SX Roof Platform with some 4x4 accessories and a whole lotta torque
It could be one of the ABS sensors is loose as apparently it uses them to measure the diameter of the wheel to know if it has a puncture or is low on pressure
If you have been over rough ground or ran over something that might have bumped one, that could be the causeLast edited by Guest001; 06-02-2014, 08:23 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Forgot it was one of them
Do they have batteries in them I had a set that did and it was usually the battery died and gave faults but that set showed which one it was.2021 Kamiq LE 110 , Moon White, BV cameras F & B
OK so I have tried over filling the tyres and holding down the button and yelling at it but nothing has worked so far.
How do you go about replacing the batteries?
I don't suppose this issue would be covered by Allianz Extended Warranty? I haven't had to use them for any claims so far...
Probably have to strip the tyres and change battery and replace and balance. $30 per corner perhaps. Mine use Li ion batteries which were supposed to last a long time but didn't always so I bought a packet of them off Ebay which were much cheaper.Originally posted by RRR036 View PostOK so I have tried over filling the tyres and holding down the button and yelling at it but nothing has worked so far.
I don't suppose this issue would be covered by Allianz Extended Warranty? I haven't had to use them for any claims so far...2021 Kamiq LE 110 , Moon White, BV cameras F & B
If the vehicle uses a direct TPMS (i.e. fitted with individual TPMS sensors), then it's usually possible to identify which tyre or sensor is causing the alert through the vehicle's multi-function display (MFD), but I suppose exceptions exist.Originally posted by RRR036 View PostMy R36 is complaining to me to "check tyre pressure". I have checked and sure enough it's fine. I'm guessing one of the sensors have died - is there a way that I can check to see which one is returning a faulty value?
First and foremost, let's eliminate the basics before taking the more expensive and time-consuming route of diagnosis and/or replacing parts.Originally posted by RRR036 View PostOK so I have tried over filling the tyres and holding down the button and yelling at it but nothing has worked so far.
Read the owners manual carefully and ensure you are completely familiar with how the TPMS operates on your particular vehicle, which may be different to vehicles using an indirect TPMS.
There are two sets of tyre inflation pressures for the vehicle: one set for "normal load" (or half load) and another set for "full load". Likewise, IIRC, there are also two threshold settings for the TPMS: "normal load" and "full load". This means that the system will give a false alert if you inflate the tyres with the "normal load" figures while the system is set to "full load".
One must also take temperature into account. For a fixed volume, pressure increases when temperature increases (gas law). So if the tyre is warm, you need to compensate for this by approximately adding between 2 to 4 psi.
For example, if the recommended inflation pressure is 39 psi (with TPMS set to "normal load"), then:
Warm tyre (car driven to service station): fill at 42 psi.
Cold tyre (ambient temperature): cools down to 39 psi = correct inflation pressure.
Warm tyre (car driven to service station): fill at 39 psi.
Cold tyre (ambient temperature): cools down to 36 psi = underinflated, which triggers TPMS warning alert.
It is best practice to adjust the inflation pressure when the tyre is cold (i.e. at ambient temperature).
If none of that fixes the issue, then you may have to look at getting the problem properly diagnosed.
With great difficulty, I imagine.Originally posted by RRR036 View PostHow do you go about replacing the batteries?
The lithium coin batteries installed in many TPMS sensors are not designed to be user-replaceable. The battery will either be soldered on (tab configuration) and/or encased with a potting compound (usually synthetic resin) to protect the electronics from excessive heat and vibration.
In addition, TPMS sensor manufacturers usually use industrial-type batteries designed for high-temperature resistance, which might make them more expensive to purchase than ordinary batteries.
The usual procedure is to replace the entire sensor, warranty or otherwise.Originally posted by RRR036 View PostI don't suppose this issue would be covered by Allianz Extended Warranty? I haven't had to use them for any claims so far...
Maybe try contacting Allianz and ask if the policy covers TPMS sensors.
Generally speaking, most vehicle manufacturers cover TPMS sensors under the original factory warranty, if there's an accompanying fault code (including low voltage or low battery faults) and there are no obvious signs of damage caused by you or a third-party (e.g. tyre fitters).
For any other warranty, including extended warranties promoted by the vehicle manufacturer and sold through a dealership, it will depend on the policy.
Saw these on Ebay
VW Audi TPMS Sensors 315MHz Set 4 S018BK 2 3458294761 SE55001 Tire Sensor | eBay
I asked the seller about the batteries and he replied saying the whole unit must be replaced if the battery dies2021 Kamiq LE 110 , Moon White, BV cameras F & B
