I've definitely got gremlins. First the map scale decides to change everytime I start the car, and now the microphone has stopped working. A couple of times over the last week my phone hasn't automatically connected, so I've done it manually only to find that the preset phone numbers on the satnav have been wiped. Now the phone connects OK, but I cannot be heard when making/receiving calls. I tried the Voice Commands, and after "Pardon" I try again only to hear "Cancel". It's obvious that the mic isn't working. I've done soft resets, and pulled the head unit out, but the block connection appears OK (Everything else is still working normally). The BT unit hasn't been touched, but I'll check that connection later today.
I had a dodgy satnav antenna replaced recently, and the dealer said that they had "cleared several faults" that appeared when they connected VCDS. I'm not a great believer in coincidence. Does it make sense that something is amiss with the coding?
