Bluetooth 9w7 assistance required
  • #16
    Re: Bluetooth 9w7 assistance required
    Was a good result.
    I will do a writeup soon in case we can assist anyone else as well as compile a compatibility list of phones.
    Sent from my HTC One using Tapatalk 2
    • #17
      Originally posted by kamold View Post
      Is your One X rooted? RSAP ap won't work without root access as it needs access to the bluetooth stack on the phone which is protected by default.
      I personally use this ROM on my (now my wife's One X).
      HTC are notorious for using a proprietary BT stack on their phones which breaks other things as well, such as A2DP not displaying song info. I now have an HTC One which works properly with A2DP. I have a 9w7 BT module in the car so I can't test RSAP for youz.
      If anyone in Sydney has a 9wz and wants me to test RSAP with Android would be happy to test.
      nope, my one x ain't rooted.
      i just got it late last year - would prefer not to root it. but if it means getting rsap functionality, i just might.
      whereabouts in sydney r u located? if u don't mind, the next time i'm in sydney, i'd like to check if ur htc works in rsap mode with my 9wz.
      if all is good, then i'll go ahead & root my one x.
      in the meantime, i'm downloading ViperX 3.7.1.
      • #18
        If you are concerned about warranty once rooted you can always relock the bootloader and return it to stock Rom. Like a car they would have to prove that modification caused a failure.
        I am in Baulkham Hills.
        Happy to test my HTC One and or One X.
        Then we can add them to compatibility list.
        You won't regret installing viperx. Just make sure you have a backup before you unlock the bootloader as this does a factory reset on the phone.
        • #19
          thanks for that.
          i'm in sydney next on july 6-7.
          i'll try and tee up with u for sat 6th june. hopefully that suits u.
          will msg u closer to the day.
