RNS510 white screen of death
  • RNS510 white screen of death
    If I had a RNS510 unit that's works but gets the white blank screen problem and had a perfect working RCD510 unit, is it possible to take the screen or board out of the RCD510 and use it to fix the RNS510 ??
    I would say no but never tried it... have you tried disconnecting the battery for 10 mins and refit and test to see if the white screen goes? also there may be a software update for white screen issue for RNS that can be done by a dealer and may be outside of a dealership too...VDUB...
    BRISBANE / GOLD COAST
      You can get a new RNS screen for not too much if it comes to that:
      RNS510 - LED Display L5F30818P01
      The RCD screen and digitizer is not compatible with the RNS, they have different connectors.
      It would be worthwhile pulling the RNS510 apart and reseating the ribbon cable which connects from the mainboard to the touchscreen, it could possibly be slightly loose.
      Replacing the screen is a bit fiddly but not nearly as difficult as on a phone due to everything being bigger.
        Awesome advice guys, really appreciate it.
        Hopefully I don't have to buy parts for it.
        If and when I get it figured out, I'll let you know.
        Thanks.
