Originally posted by Martin
View Post
Auto-Polar FIS+ Advanced - Complete Guide
Thanks mate - you're absolutely correct - the problem was my VCDS
I'm running V12 which is beta - it was saying the software is "out of date" on startup, but it's not connected to the network so I assumed it was time limited - I've upgraded to the latest V12 beta and everything is working now (phew!)
Now - to configure the screen contents to display
Screen 2 is almost impossible to scroll to, get's skipped 7 times out of 10
I am also having problems with the window dipping feature despite reading/watching info - will try again
Update: Window dipping in manual mode working (does automatic only work with the car operating?)
Does the trim alter the dipped or driving position???Last edited by Martin; 23-02-2013, 01:24 PM.2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Mirror dipping in automatic mode only works when you have the indicator on i.e. when reverse parallel parking.
I haven't played around with the trim much. The offset changes the position the mirror returns to. If you find it returns too high/low you can adjust the return position up or down using the offset value.
Window dipping?
Originally posted by Ryan_R View PostWindow dipping?
They're mirrors, silly
Originally posted by tigger73 View PostWindow dipping in automatic mode only works when you have the indicator on i.e. when reverse parallel parking.
Originally posted by zei20t View Postahhh indicator and reverse is 'auto'! thank for you that. ill set mine to auto
I'm using manual mode as I find it useful to have the mirror dipping when reversing out the driveway.... and I don't want to have the indicator on while doing this
Originally posted by Ryan_R View PostThey're mirrors, silly
I'm still trying to get the auto window closing function going though.... tried a couple of times but no success.
Isn't there a normal MFD setting for that - or it's at least available via VCDS. I prefer to have manual control by holding lock/unlock on the key fob (i.e I'll often get out of the car, hold unlock to open all windows a smidge, then lock the car).
Originally posted by tigger73 View PostYes it doesn't matter where your mirror selector switch is set (so I believe). As soon as you have reverse gear and your indicator going the mirror will dip.2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Originally posted by Ryan_R View PostI prefer to have manual control by holding lock/unlock on the key fob (i.e I'll often get out of the car, hold unlock to open all windows a smidge, then lock the car).
(This is prior to installing the Polar FIS)
I love using the key to fully open the windows before reaching the car - really useful
Hate openning the door and getting a blast of hot air2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Same here - I time the window opening just as someone else is about to walk past to freak 'em out
My cat jumped into the car, I remotely closed the window
The look on it's face looking out of the now closed window was priceless (what am I gonna do now?)2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
I was talking about auto-closing on sensing rain.... not cats
