Hi, I've read a heap of threads off this forum and other bits of the web and have a couple of questions
1. Does the Tig come pre-wired for an RVC? Presumably RGB wiring but I could use that for composite.
2. I'm only using one of the 2 antenna cables into my ANS810 head unit, presumably the shark fun.
If the other cable is the heated rear window antenna then could I use that as the video feed? Presumably thats 50ohm coax but it might work?
Anyone tried anything similar ?
Many thanks.
Many thanks.
