I fitted the rear emblem reverse camera to my Golf R some time ago now, but I finally got my hands onto a VCDS cable and programmed the RNS510 byte3 bit 5 (from memory, but it is highlighted as "Backup camera (low) without control module installed") for the RVC, and it doesn't work
So, what I do see when I toggle that bit is an icon shows up next to the OPS mute icon on the bottom right of screen when going into reverse, when I press that button I get a black screen with arrows on it to minimise/maximise the fully black area.
I was under the impression the camera image came up automatically? (and I take it there is no OPS graphic when selecting the rear camera?)
Also, not sure if this is a result of my fiddling, but I see in the vag com scan log a "02873- Control module for backup camera j 7772 no signal/communication" under my navigation scan, buy I didn't get the control module one, just the one to plug into the back of the RNS?
Anyone have one not fitted that we can test whether it is my camera or coax cable or programming?
My camera certainly pops up when selecting reverse, and the unlocking works properly with the handle & remote. I definitely tapped an always on power source & tapped the reversing light. My RNS is running the latest f/w avail here or on vwgolf.net.au.
