Hi All,
I had a flat battery in my car last week and ever since then I have had nothing but problems with my RNS510. RACV installed a new battery… after turning the car over with the new battery, I had to scan the car and clear all fault codes to get the central electrics to work (windows wouldn't roll down automatically etc..), that was all fixed.
However, with my RNS510, it won't appear at all on my MFD Cluster, it only has the fuel consumption and Telephone "Insert Phone", won't allow for volume control changes at all…
Pressing the MEDIA button (for Hard Drive and MDI) it says 'this function is not available' and pressing PHONE will mute the radio.
I have tried upgrading firmware from 3810 to 4020 (no go). I then formatted the RNS510 (with the special format image) and downgraded back to 2760, no go, same thing. I've also noticed, after rebooting the unit, it won't turn on automatically, I have to manually turn the RNS510 on, the lights around RADIO,MEDIA,PHONE etc.. no longer light up apart from booting up for the very first time. When removing the key from the ignition the unit stays on and will not turn the unit off anymore.
I have a VCDS log with the errors… since it can't see the module at all I am thinking it is an error with the CAN Gateway, or the CAN is stuffed after replacing the battery.
I then decided to take the unit out and remove the cables from the back and re-seat it, and reboot, still made no difference.
I even tried going into the CAN module, long coding and unticking Radio and Telephone, reboot and then re-tick, still not working.
At this point I am thinking something is definitely faulty, whether it be the RNS510 or the CAN, I am not sure.
Here is a scan log:
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 230808F2000959
Coding: ED807F0ED006120003
Shop #: WSC 30067 959 100563
VCID: 354FF35E5C5A571
4 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
00467 - TV Tuner (R7
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
Have you seen this issue before as I am trying to work out what the hell is going on?
I have a 2009 VW Golf GTI Pirelli Edition, with an RNS510 Revision B (now downgraded back to 2760).
I would really appreciate any help I could get right now
Best Regards,
Dean
Here is a scan log:
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 28733 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:56
Best Regards,
Dean
