Hi all,
I installed a reverse camera to my 2007 Jetta today using the following simple guide.
That is, video cable wired to front of car and camera powered through tapping the reverse light.
It works when i tested it without the engine running (ie. key in ignition one turn). I put it in reverse and the pretty picture shows on screen.
PROBLEM: However the camera does not work when i have the engine running and i put it in reverse. failed..
It is because VW's have some sort of power regulator to the reverse light stopping enough power going to the camera when the engine is running?? I can't think of anything else.
I have wired it this way for many other cars and it works fine.
fyi, i have an ebay GPS rns510 look-a-like head unit. (works fine)
