MY08 jetta - Upgrading a RCD300 to RNS510
  • MY08 jetta - Upgrading a RCD300 to RNS510
    I have a 2007 but MY08 Jetta TDI
    It has the rcd300 along with the full height red MFD and no bluetooth.
    Have done a fair bit of research but wondering if someone could confirm that i can install the RNS 510 and the FISCON basic plus bluetooth kit
    From what I have learnt if i install these both..
    1- Wont have a battery drain issue due to the newer CANBUS
    2- Will have the bluetooth kit talk to the MFD and not only give caller info but also car info (boost, oil temp)
    3- bluetooth will work with the RNS 510
    4- The only programming that will be required is to tell the car that there is now bluetooth and sat nav installed.
    Also looking to get this mic
    Also if anyone knows of good people in Hobart for coding..!
    Anyone have experience with upgrading this?
      You asking something that there are a lot of threads about. Check the stickies and use the search.
