Remote central locking Golf GTI mkIV
  • Remote central locking Golf GTI mkIV
    Hi guys,
    I would like to add keyless remote entry to my gti mk4. I want to use a flip style 2 button key with transponder chips. My question is what module do I need to add to my system, that would be compatible with programmable keys. I have searched the internet, but only found aftermarket systems. However I think that the operating frequencies would be different to the progammable keys for sale. I am a novice to VW's, so hopefully I havent confused everyone with my rant.
    Thank you all in advance.
    I've also tried to research this, I was told that the mk4 boras module/remotes may work but I've come to the conclusion that an aftermarket system will be quicker and cheaper to install.
    Still looking into it........
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
      This could be an expensive add on!! Never seen it done myself but guessing you will need convenience module that has remote operation then you will need remotes and folding flip out key with immobilizer built in which all will need to be coded to suit. I'm aware of a votex kit that was available as a genuine accessory these hook up to original wiring and allow window roll up and down function.
      Sent from my iPhone using my fingers.
        Came across this
        How to fit aftermarket remote central locking to mk.4 Golfs/Boras. - uk-mkivs
        Ducati 749
          This is exactly the article i used to do mine. works perfectly sunroof and windows close when pressing the lock button. Was quite easy to do as well. I used a different system i found on ebay for about $60 delivered.
