Two antenna cables?
  • Two antenna cables?
    Hi,
    I just fitted my Alpine unit in to the Eos at the weekend and was stalled for a short time on the two radio antenna connections to the back of the stock head unit.
    I have connected up just one of them to the antenna adaptor I bought but was wondering why there are two? Does anyone know?
    Thanks,
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Yes its a twin Antenna one lead is FM the other is AM .
      Ah, didn't think of that, interesting. I don't listen to AM radio so I can probably leave it for now, guess I accidentally picked the right one to connect!
      What would be the solution then if I wanted both connected to an aftermarket unit?
      Adam
      Previously -
      2002 Bora V5
        Adam
        I think that would depend on what connection you have on the Alpine you might be able to combine the two into one ,i'm sure any radio installer would have a solution.
          you can get a 2 into 1 Fakra adaptor.Search ebay
            There are two different antenna's, one is better tuned for FM, the other for AM. As borbor suggested a twin-fakra antenna adapter will allow you to connect both antenna's, and will improve the signal in weak signal areas (for both FM and AM). Around Brisbane one antenna is fine for both FM & AM until you get into the fringe areas.
            Al..
            2013 MY13.5 Passat V6 Highline Wagon. Watch this space
            GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
              Thanks guys, I will have a look and see how much the adaptors are, I like to do a job properly if I can.
              Adam
              Previously -
              2002 Bora V5
                For anyone else changing their stock MKV / Eos headunit, this is what you need:
                Antenna adapter amplifier AUDI VW Skoda Twin Fakra DIN (eBay item 330547117920 end time 27-May-11 00:57:50 AEST) : Consumer Electronics
                Adam
                Previously -
                2002 Bora V5
