RCD310upgrade to RCD510 in a new Polo GTI
  • RCD310upgrade to RCD510 in a new Polo GTI
    Hi all
    Sorry if this has been asked elsewhere.
    How hard is it to upgrade the RCD310 to a RCD510 in the new Polo? Will everything (Display and steering controls) still work OK?
    Polo GTI 5dr Candy White
    Originally posted by nugget1312 View Post
    Hi all
    You should ask, if it was done before? I didn't see the thread about it, but if the radio has the same dimensions, then it should fit and work.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      go ahead , Rcd510 must be OK on your newPOLO .But password for rcd510 is needed.
      Tiguan 125TSI DSG7 naked version with RVC ,BT9w7 ,OPS ,PLA1.5 ,RNS510 ,150W AC-POWER ,FOG light,LED DRL installed at home
      Multivan comfortline 2.TDI DSG7 with RVC BT9w7 ,OPS,RNS510
        Hi , I dont have the polo but I have the MK6 77tsi and I have upgraded from the RCD-310 to the RCD-510 myself.
        It was very simple just be careful clipping off the front beazel, you will need a torx kit to take the 4 screws out but the wiring was all the same as they use the universal plug. I spent more time taking the front off than the time to connect and screw it back in.
        Oh another thing which I found. When I first turned on the RCD-510 its language settings restore back to German so its easy to follow the pictures in the manual to change to english.
