Firmware upgrade for rns 510 - 2760
  • Firmware upgrade for rns 510 - 2760
    Hi All,
    Thought I'd just let everyone know, just in case anyone was thinking about updating their firmware, that I updated my RNS 510 to version 2760 from:
    Volkswagen RNS 510 Firmware Upgrade to version 2760 / 2762 / 2764 / 2766 / 2768 | my-gti.com
    No issues and I am using V3 maps and I am able to use SDHC cards (the main reason why I updated the firmware).
    Cheers.
    Hi l3lazin.
    Hope you can help with a few questions, I want to do the same upgrade.
    - What Model year is your VW ?
    - do you know your RNS 510's version of Hardware and firmware before the upgrade ?
    - Did you lose any music or your maps ?
    - Did you have to reprogram the steering wheel controls after the upgrade ?
    And lastly, did any of these work for you after the upgrade ?
    - digital speed display on MFD
    - Speed limit display on map
    - shows clock when switched off
    - dual zone controller Climatronic control
    - Faster Startup
    - SDHC 32 GB Support
    a bunch of questions, I am just a little cautious before doing the upgrade.
      Hi spanky,
      Sorry mate, haven't checked the forums in a while, I will try and answer your questions the best I can, to the experience that I have with it:
      2009 MKV GTI (the last of its kind)
      Nope, I winged it, at work now but when I get home, I will post you the firmware and hardware versions, I was just banking on the fact that mine was the newest of the MKV.
      NOPE!, it was just a firmware upgrade
      NOPE!, no need to do that either.
      Also to note, after the upgrade, the unit doesn't know where it is, so go for a drive and it should find itself. If not then force the restart by holding the 3 buttons, and you should be good to go!
      Nope. Never did work.
      Not sure what you mean, but mine are controlled by the dials.
      - Faster Startup
      Not really.
      YES. This is the big draw card for me!, 32GB support!, one thing is, that after I turn off the car and come back, I get a SD CARD read error. I just have to push out the card and back in, and its happy again.
        Time display on after upgrade
        Hi
        After my upgrade I was able to see the clock when the unit was off. You need to change the settings:
        Setup->time display-> on
          yeah thanks mate! So the clock works.
