Ok, I finally replaced standard radio in my T5 with Clarion FZ409A but after plugging in the 2 ISO connectors radio is powered even when I take ignition key out. Another set back is that antenna connector is different and I can't play radio yet. Do you guys have any idea where to get the right antenna adapter (Idon't want to cut the original connector).
Clarion FZ409A in T5
Tags: None
Well, the unit is working properly now. The wire no.4 and no.7 at no. 2 black connector needed to be swapped, but still needs antenna adapter.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Transporter,
Can't help with the antenna adapter unfortunately.
I just replaced the head end in my T5 with a Kenwood, and everything worked fine with the exception of the AM radio, as company fitting the unit said that the antenna needed power, and there was no way that they could see to get power to it. The FM works fine, so I don't know what the difference is. There was some comment that the antenna was Can-bus
I think the easiest way to fix the issue for my installation may be to install a new antenna. Hope yours is different, but I think we both have the same model and year T5.Golf V TDI 2005 - SOLD
Volvo C30 D5 - I've got a hat as well!
Multivan Highline T5 TDI 4Motion 2005
Hond Civic VTI 2001
