I used Toast 9 to burn this on my mac. You have to burn it as per the instructions as an image file I think, can't remember exactly now but that was the hurdle I had to get over. It is just a tick box on the toast preferences.
Volkswagen RNS 510 New Firmware Release
How do you know if you have an A B or C unit?Originally posted by Maverick View Post<5 minutes.
It appears that release 2660 is intended for C revision units.
2670 is coming out shortly.
2700 will be out early next year and will most likely be stopped from being loaded onto A & B units.
And version 1200 will be coming out shortly as well which is designed for revision A & B units and the only features it adds is SDHC and POI photos.Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
Unless you have the hidden setup menu available to you by pressing the setup button and keep holding it until the second menu appears, the only way to find out is by using the VAGCOM cable or remove the unit. There may be a label at the back.
I have just installed version 2660 and its great. I can now use 32gb SDHC cards and also use picture POIs. I'm buying a VAGCOM cable so I can get voice control working.
Try a different brand of media and burn at a much slower speed.Originally posted by 111 View Postive tried many a time to burn this image and load it and i keep getting the same CD/DVD error on the screen
what am i doing wrongwebsite: www.my-gti.com
RNS510 A B and C Units
Have A, B and C units been a time thing. That is A followed by B followed by C or are they just different units randomly fitted to vehicles so. Are all version units still being installed OEM?.Originally posted by Maverick View Post<5 minutes.
And version 1200 will be coming out shortly as well which is designed for revision A & B units and the only features it adds is SDHC and POI photos.You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
2660 Update = Version B RNS510
Anyone have the 2660 update working on a Version B RNS510?Originally posted by Maverick View Post<5 minutes.
And version 1200 will be coming out shortly as well which is designed for revision A & B units and the only features it adds is SDHC and POI photos.Last edited by Highlander; 07-03-2010, 10:51 PM.You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
I loaded this today. I can't see any differences at all, although I haven't had an extensive play with it yet. However, apparently my car now thinks its in Germany. I'll keep playing but perhaps hang off for a few days yet!
EDIT: After a few minutes driving around I am back in Oz, so no apparent problems at all with the update. However, no obvious benefit either. This is the 2700 version, not the 2720. I'll wait for someone else now. Funny that 2720 followed so soon after 2700! Perhaps it says something about 2700?
Do you know which RNS510 you have. A B or C?Originally posted by mtaoz3 View PostI loaded this today. I can't see any differences at all, although I haven't had an extensive play with it yet. However, apparently my car now thinks its in Germany. I'll keep playing but perhaps hang off for a few days yet!
EDIT: After a few minutes driving around I am back in Oz, so no apparent problems at all with the update. However, no obvious benefit either. This is the 2700 version, not the 2720. I'll wait for someone else now. Funny that 2720 followed so soon after 2700! Perhaps it says something about 2700?You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
