Radio information locked.
  • Radio information locked.
    MIB3 discovery media
    2017 Golf.
    Many FM Radio stations programs shows all the info on the screen the temperature, the hosts, the music, etc.
    But just last week it appears to be stuck on the station ID and the music title and artist.
    What makes this unusual is that in the morning at home it works well and changes with each song. But i get to work, park the car and when it's time to leave its stuck on the same song/details form last week.
    I have tried deleting the station but still does it.
    It's also only on the one station. All other stations it's fine.
    Any suggestions?.
    Sent from my SM-S916B using Tapatalk
    Michael: I don't have the definitive answer to your question - but maybe if you understand how the information about "the station ID and the music title and artist" is received by the MIB on this car, you can answer your question, yourself?
    So, here in the Antipodes and in addition to the fundamental audio signal (which is transmitted using an analogue radio protocol) - FM radio also transmits a digital channel called Radio Data System (RDS) which allows for the broadcast of data like "the station ID and the music title and artist". So, each major FM station (meaning Capital City and provincial country stations) in Australia has its own pair of both analogue and digital channels
    However, the thing about RDS is that proper reception of the digital data is more prone to the strength of the primary radio signal. It's probably too much information for this reply - but this happens because RDS is transmitted over a sub-harmonic frequency of the FM stereo signal. This means that often on FM stations, when stereo reception is lost because of a weak signal - RDS also fails!
    So, I would be interested in your reply - but maybe the location of the car at work is such that for the signal strength for the problematic FM station, the primary audio signal can be received - but RDS (and likely stereo) reception is intermittent. Perhaps border-line RDS reception causes the digital information (like "the station ID and the music title and artist") to freeze as you explain in your post? I'm guessing- of course!
    Don
      2017 Golf.
      Was that retro fitted?
      Asking because the MIB3 was released in 2019 on the Passat.
      Flipper Dog
      Now - T-Roc R, Audi Q5
        My 2019 Tiguan still had the 2.5.
          Oops, maybe it's the 2. Anyway it's that came with the ar and no retrofit.
          I haven't even upgraded the GPS (which is way out of date).
            Just an update. My mechanic did a factory reset, and now now problems. All good.
            (If I had done it, I would have probably destroyed the entire electronics [emoji1787])
