Hello everyone! I recently got rns510 hw04 and it came with firmware 1100, i tried to install fw 5238 and it failed on hdd part, now i am stuck on enter code screen with my touch not registering and i know it's not the screen that's the issue since ok and cancel buttons on fw upgrade screen register. Tried swl fix and other versions of firmware same thing.. Glad to hear your suggestions! Thanks
1 of 2
2 of 2
RNS510 help!
Try loading 2680 factory.
Once that is working load 4120 factory.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hello, thanks for reply. I can not load load older firmware since the 5238 update failed.. I can only load newer fw because Install older fw option in settings is not enabled.. yikes.. what do i do now? it won't take older fw.. do i format hdd?? what are my options since there is no rns service in serbia :'(2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
Ah I see.
Sorry wasn't thinking about that. With Setconfig or similar tool you can enable this without having to go into the menu.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Update:
Managed to get it in somewhat working state with swl_fix.. Now i can type radio code and touch works but there is no boot logo and sw version is just - .. BUT only if i leave hdd unpluged will the touch work, if i plug hdd back in the dvd drive stops working and touch is not working anymore.. i need to do swl_fix once again with hdd unplugged for it to get back in touch working mode.. Tried enabling fw downgrade in setup and starting varius fw updates(1300, 2760...) and it does not start
Interesting that the unit is stamped with 2xxx firmware, and you said it came with 1100.
With the issues you are having loading the firmware, maybe the HDD in the unit is failing?MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
the unit actually shows ''-'' as firmware version now, and does not want to take any fw updates(1300, 2720, 2760, 3810..) only the 5238 update by josi then it bricks my unit- prevents from typing radio codeLast edited by cveya; 06-07-2023, 12:28 AM.2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
Originally posted by MIG View PostInteresting that the unit is stamped with 2xxx firmware, and you said it came with 1100.
With the issues you are having loading the firmware, maybe the HDD in the unit is failing?2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
Originally posted by Hillbilly View PostYou need to burn discs really slowly and use good quality ones Not Princo crap or stuff like that , And not rewriteables2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
Can you give us a bit more background on the unit? Did you buy it second-hand from a wrecker, or was it a known good unit?
Here is the link to the teardown and SSD update that johnc made RNS-510 HDD replacement/SSD swap DIY ; if the HDD has died, I would recommend going to an SSD or CF card with an adaptor like in that guide.MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Originally posted by MIG View PostCan you give us a bit more background on the unit? Did you buy it second-hand from a wrecker, or was it a known good unit?
Here is the link to the teardown and SSD update that johnc made RNS-510 HDD replacement/SSD swap DIY ; if the HDD has died, I would recommend going to an SSD or CF card with an adaptor like in that guide.2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
