Passat B8 3G Discovery in a Golf MK7
  • Passat B8 3G Discovery in a Golf MK7
    Hi,
    I just came across a pretty good deal with the above head unit and I would like to know if someone had successfully installed in a Golf MK7 before or if it’s even compatible with.
    I have a golf wagon 2014 with the basic head unit (I think the MIB1) and the Passat one has Carplay. The Passat part numbers are 3G0 919 605 D for the screen and 3Q0 035 846 for the receiver.
    Thanks.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI colour cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
    Yes it's compatible but requires handling of Component Protection and Feature Enable Codes (FEC) as well as coding and adaptation.
      Thanks for the reply!
      Apart from the Component Protection the rest could be done with the VCDS?
      Thanks again.
      PS: You're a LEGEND! when I had my Passat Wagon B6 I was always reading yours retrofitting threads and helped me a lot doing some mods.
      More to come...
        VCDS can only do coding and adaptation. CP and FEC need to be done by other means.
          Do you know anyone in Sydney/Central Coast that could help me with that?
          More to come...
