Replacing RCD 310 to RNS 510
  • Replacing RCD 310 to RNS 510
    Hi Everybody,
    I am new on the platform. I would like to mention about my problem what i am having currently.
    I had RCD 310 in my Jetta 2013 TDI, I changed it to RNS 510 (without VCDS coding etc.)
    then i turned on the device everything was good except navi. because navi was showing West Eu map. Therefore i wanted to change it to V13 East EU map.
    Then I prepared SD cart with the v13 map and DVD which is for copy files from SD to HDD.
    however, after that i uploaded the map by following procedures in here "https://paulroberts69.wordpress.com/2015/10/01/upgrading-firmware-and-maps-on-vw-rns-510-satnav/"
    the map info showing "-". that means although everything was performed ok, the even current map has been deleted.
    I appreciate for your help .
    Is there something wrong with the DVD drive?
    Can you try loading the map directly from the DVD?
      No i did not do it yet. onoe more thing there is no GPS antenna (i think it should not affect the head right?)
        Not having a GPS antenna connected will not prevent the maps from loading and displaying correctly.
        It just won't show the correct position on the map.
        Sent from my HTC 10 using Tapatalk
          When i put dvd, the map is showing copying to HDD. after that is done, the device restart itself. then i check the version info, it shows "-" for map info. and when i pressed nav button, it says "please insert map dvd".
            Might be a problem with the HDD.
            Can you copy music to it?
            Does it have a HDD?
            Early versions did not have one at all, nav comes from DVD
              Yes, HDD have around 100 pcs mp3. i check HDD deleting couple mp3. but i did not try to copy.
                What firmware version is installed?
                  5238 is currently seen in version info.
                    Do you have a different maps DVD you can try?
                      I don't have any other DVD for different maps because i dont know which version of map is compatible with the device. i dont want to do something wrong. shoud i try it?
                        All maps are compatible with all sw versions, they are just more up to date map contents.
                        So you can load an earlier map to test.
                        Then load the newer map which will replace it.
                          I would like to found V10 version map is it ok?
                          let me try to load it via DVD. then i let you know about the result.
                            Sounds good
                              Hi,
                              It worked, when i tried to load v9 map by DVD. but there another problem occurred. the device think it is in Germany because when i try to use it, shows Germany map. but i am living in Turkey .
                              I checked GPS status, there no seen GPS signal and satellite. is it related GPS antenna? because i did not receive my GPS antenna order yet.
