Hi, new to forum mk7 R cabin sounderkater knot shaw of correct spelling, wanting to know about how to delete or reduce sound % I understand it can be adjusted from 100% to zero in 10% amounts whats the pros and cons! Would like to adjust to my likeing I myself think its a bit on the loud side, any recommendations or advice on a good setting % ! Regards G.T.
vw golf mk7 R Sounderkater
Originally posted by G TODD View PostHi, new to forum mk7 R cabin sounderkater knot shaw of correct spelling, wanting to know about how to delete or reduce sound % I understand it can be adjusted from 100% to zero in 10% amounts whats the pros and cons! Would like to adjust to my likeing I myself think its a bit on the loud side, any recommendations or advice on a good setting % ! Regards G.T.
Todd: not sure what tool you are using, but the process is easy! As to the volume for the Sounaktor that should be used, this is very much a personal thing. Because the process is so simple, just try a number (the percentage number can be changed in single digit numbers) and if you don't like it, then try another value.
Anyhow, if you are using VCDS, try this:
or if you have OBD11, try this
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
