Coding Westafilia towing. Harness
  • Coding Westafilia towing. Harness
    Any one know about the coding of a westfalia towing harness
    I had a friend on the weekend attempt to code it and 90%. Is fine except I dont
    have tail lights
    The trailer is ok because it works perfectly with. My Navara. Ute
    Any help appreciate. Thanks.
    Any where between. Blacktown. And Penrith.
    The independent VW specialist workshop should be able to help you. I'm not using VCDS for these kind of jobs, so can't help you. My other scanner does it automatically.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      Thanks. Transporter. SA. Was a bit too far for me to take it
      But there might be some one. Here that can sort it out.
        What vehicle are you trying to code?
        I had my Amarok coded by Wakelings in Campbelltown, charged me half an hour labour last October.
          As in my Avatar a Tiguan 2014/15 its just the tail lights blinkers and stop lights all work ?
          was yours the Genuine VW or Westfalia harbess?
            Westfalia form JKU, (the same as the VW one.) it has LED compatibility, which is the new version so better.
              Got this from Euro cars could be right as im using a 7 pin round to a 7 pin flat it only pick up one of the tail lights
              Hello Ian,
              my installer told me that:
              1. the boot lid has to be closed for testing (many people forgets about this )
              2. when you code this module to Australia only one pin for the lights works, it is 5 OR 7, we can't remember now, but the point is, you have to check which one is it with the 5w - 20w bulb and then check if its the same pin in the trailer wiring.
                AFAIK the westfalia module is mostly plug and play, but sadly the most important part is not coded. the ABS module will change the active stability when you have the trailer attached, the CECM will disable your rear parking sensors and the TCU will change the shift points.
                there were a few check boxes in VCDS to get it all working correctly, but its not a huge job.
                im using the 13 pin euro plug.
