OBDEleven - The new kid on the block!
  • New one does iOS (but only read and clear error codes to start with), up to 18 times faster, and can do other manufacturers
    • Originally posted by Jap View Post
      Not till q3 2019 it says
      • Originally posted by Hillbilly View Post
        thats for iOS doing pro stuff fella, iOS at release but only read/clear errors/dtc’s
        In June 17th. Note: you can use iOS application for vehicle identification, Read/clear/share fault and One-Click-Apps. PRO version for iOS will be available in Q3 (July-August-September).
          Thanks for the update. They must have just got in some stock of the V1.
          I've ordered one - price seems reasonable. At least it's coming out of Melbourne and not from Europe.
          • So for those of us who have the original OBD11 dongle, will it continue to work, or are they phasing out support for it, in favour of the newer version?
            2016 Skoda Octavia 162TSI RS Wagon
            (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
            Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
            • Originally posted by Spinifex View Post
              New one is similar but better so old one will continue to wrk I would think.
              Will be lots of screams if it doesnt I bet
                yes it will continue to work, no they are not phasing out support, the newer version is basically new hardware to a) make it faster and 2) work on iOS and three) add support for more brands of vehicles (I think BMW is next)
                  I think what people are asking is, for how long they’ll continue to support old hardware?
                  We have members here who could know and they’re suspiciously quiet.
                  One way or another they can limit the old dongle so it won’t work or only work with limited functionality on the newer models.
                  On the plus side. The OBD11 advantage is that is cheap and you won’t be throwing out several thousands $ scanner like it happened in the past with some other brands.
                  Performance Tunes from $850
                  Wrecking RS OCTAVIA 2 Link
                  • Anyone got Traffic sign recognition to work I did it with the app and seems it said it accepted it but no signs appear I rebooted unit by hoding down the on off button till it shut down and came back on but no go so far.
                    Dont want to waste another 100 credits for nothing Also tried high beam assist but it didnt work either and car has all the necessary bits
                    • Originally posted by Transporter View Post
                      see all I see is a obd port scanner connected to a Bluetooth that sends info to the app, so unless the obd canbus pin outs change (v+, v-, can high speed (2 wires) and can mid speed (again 2 wires)) then I don’t know why you wouldn’t support the hardware,
                      • hey guys,
                        ive got one of the next gen obd11 units and so far made some good changes.
                        so far the best changes was deactivate start/stop and changing the throttle responce (although it could be more responcive still)
                        just tried adding street sign but as in restrictions here couldnt really go and check.
                        something else id like to see if possible is remote start, i know its a feature on us delived passats but not aus deliverd, i have however noticed alot of parameters in adaptaions menus for remote start... anyone know if its possible?
                        any other recommendations?
                        im also about to install a audison DSP amp and small sub (hopefully under boot floor in the wagon).
                        hopefully can tune to sound much nicer.
                        ohh its a 17 passat 206 wagon
                        • Originally posted by Chad206 View Post
                          hey guys,
                          Is it a highline with camera etc
                            Chad: I wish you luck with the remote start tweak - I'm more than happy to be proven wrong, but I suspect that it might be more than just a matter of changing a few adaptation-channel/long-code settings. My suspicion is that this feature might even be "Software As Product" (SWAP) which involves a activation code linked to your VIN - but I'm guessing!
                            A very poor alternative to remote start is the tweak that enables the engine to run whilst the key fob is outside the car (without warning messages). Of course, it's not "remote" because the driver first needs to start the engine in the normal manner - but it does kind-of look like remote in the latter phase in that the driver can be outside the car (with key-in-hand) with the engine running.
                            Anyhow, if this is of interest - the tweak involves changing the adaptation channel Funk bei Klemme 15 ein to active in the module that OBD11 calls Central electrics (@ address hex09). Depending on what adaptation channel database is in your MY17 Passat, search either for "Access control" or "ZV allgemein"
                            Don
                            • Is there any way to keep the VW maps active in the virtual cockpit when using Android Auto / Google maps in navigation mode?
                              I know you cannot display the Google Map in the Virtual Cockpit, however the VW maps would be better than staring at a blank screen.
                              MY20 Mk7.5 Golf R-Line w/sound and vision pack.
                              • I've been looking around but can't find a good explanation (here or on the OBD11 website) how the credit system works.
                                The Pro version come with 200 credits, but what does it mean in practice.?
                                Is it a one off to activate an app/specific function or do you use credits each time you use the app? And are the amount of credits different for each application?
