Hi,
As per another thread http://www.vwwatercooled.com/forums/...lf-105505.html I'm chasing an issue with my Mark 6 GTI.
I've completed a diagnostic scan and only one fault was found. It relates to the flap within climate control so not an issue relating to the above.
From what I can see under OBD-II option I can only monitor four parameters when I click Mode 1 Read Data.
I found the Lambda sensor. as I understand it:
1 volt = perfect fuel burn
less than 1 volt = rich
over 1 volt = lean
1.99999 (or 2 volt) = no fuel burn. i.e out of the throttle but in gear over a certain rev threshold before the car starts to add fuel for idle purposes.
What I was able to demonstrate was:
Driving around with my foot on the throttle the lambda value was 0.88 - 0.98
Once off the throttle but still in gear the value remains around 1.03-1.05 for around two seconds then;
the value of the Lambda jumps to 1.999
Now the other vaules I selected I thought were physical throttle position and virtual throttle position. (or called something like that).
My question to the gurus out there.
1. What four values would you monitor to help me capture the fact that the car is continuing to add fuel whilst the actual throttle is closed.
I was thinking
Throttle position
virutal throttle (i.e what the car is adding)
lambda
fuel delivery.
Or am I going about this the wrong way?
over 1 volt = lean
I was thinking
Throttle position
lambda
fuel delivery.
