Hi,
I Got my BT kit yesterday and installed last night. Going from the coding instructions, it says that i need to go into the CAN gateway and add 77 - Phone to the installed list which i have done.
Then go into 77 - Phone and change the coding to 0A01000000010110 which i have also done.
However it now says that you need to go into 16 - Steeringwheel and enable the PTT function. Well In my 2011 Polo I dont have a 16 control unit. The only reference i could find to PTT was in 03 - Central Electronics which I have since enabled, but the only change that made was to disable the microphone button. It had previoulsy muted the stereo and paused any SD card music, where as when i enable the PTT in 03 the button seems to now do nothing.
I was told that given the BT unit is so new it may not function, which if that is correct but i thought i would just ask.
Also, my MFD (white) in the kombi does not show anything relating to the phone, even when i am in a call, is that right? All the pictures that I have seen have phone details showing up. Am i missing some coding steps?
Cheers,
Aaron
Cheers,
Aaron
