The RNS510 swap is supposed to be plug and play, and it has proved to be the case, in the main.
I have the standard MDI and BT but have changed the RDS300 for a "F" RNS510.
The car has been coded to recognise the unit so now, the Nav instructions appear on the cluster screen.
Thing is, the mic works for the phone but voice control doesn't.
A scan has listed the following (I have cut and pasted the parts with errors).
Anyone like to comment what might be wrong ?
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 211211F2003246
Coding: 356003
Shop #: WSC 01324 020 00200
VCID: 3B7133DF0641
1 Fault Found:
03753 - Control Module for Microphone
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 187 km
Time Indication: 0
Date: 2002.14.16
Time: 23:23:59
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
Component: RNS-MID H60 4020
Revision: AB001001 Serial number: VWZ6Z7L5236252
Coding: 04010002010000A00011
Shop #: WSC 05314 000 00000
ASAM Dataset: ------------------------- ------
VCID: 316D11F7D40D
2 Faults Found:
00823 - Line-Output; Front Left
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 184 km
Time Indication: 0
01523 - Microphone for Telephone (R3
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 187 km
Time Indication: 0
Date: 2002.14.16
Time: 23:20:08
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 316D11F7D40D
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 184 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 187 km
Time Indication: 0
Date: 2002.14.16
Time: 23:20:08
Coding: 356003
VCID: 3B7133DF0641
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 187 km
Time Indication: 0
Date: 2002.14.16
Time: 23:23:59
VCID: 316D11F7D40D
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 184 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 187 km
Time Indication: 0
Date: 2002.14.16
Time: 23:20:08
VCID: 316D11F7D40D
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 184 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 187 km
Time Indication: 0
Date: 2002.14.16
Time: 23:20:08
