Hi guys - firstly my tiggy is a 2010 (MY11) 147 - has the standard RNS510 so grabbed a new RNS510 with navigation...version H - HW 61 with software revision 3970.
I also purchased this:
VW Bluetooth KIT 7P6035730F - Retrofit -
so today I removed the old RNS510 and wired up the bluetooth kit (which was relatively easy) and hooked up the Ross-Tech HEX-USB+CAN Interface so I can carry out some coding. First thing was to carry out an auto scan and save it just in case I did something stupid then I looked for 19 (CAN Gateway) and enabled navigation and Telephone, after this they both appeared in the MFD - that was pretty simple I thought. For my next trick I went into Address 37 and check for error codes - see below:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H61 3970
Revision: AB001001 Serial number: xxxxxxxxxxxx
Coding: 04010402040000800005
Shop #: WSC 01357 011 00200
ASAM Dataset: ------------------------- ------
VCID: 336F2AB2922E49B
3 Faults Found:
00859 - Line-Output; Front Right
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
00823 - Line-Output; Front Left
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
01523 - Microphone for Telephone (R3
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28881 km
Time Indication: 0
Date: 2019.14.06
Time: 18:01:31
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Revision: AB001001 Serial number: xxxxxxxxxxxxxxxxx
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28881 km
Time Indication: 0
Date: 2019.14.06
Time: 18:01:31
It looked like to me that this was faulting as the bluetooth unit wasn't coded as it threw back the following:
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H12 2730
Revision: 1B001001 Serial number: xxxxxxxxxxxxxx
Coding: 0A00000000010100
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_VW36.rod
VCID: 356B14AA945A57B
2 Faults Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 28873 km
Date: 2019.14.06
Time: 15:43:00
13636352 - Control Module Not Coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 28873 km
Date: 2019.14.06
Time: 15:43:01
Dumb question but I have searched everywhere and my coding appears to be different than others I have viewed in this and other forums so what else do I need to enable/disable as I cannot see anything else that should be - any tips, pointers etc are most welcome TIA
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28881 km
Time Indication: 0
Date: 2019.14.06
Time: 18:01:31
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28881 km
Time Indication: 0
Date: 2019.14.06
Time: 18:01:31
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 28873 km
Date: 2019.14.06
Time: 15:43:00
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 28873 km
Date: 2019.14.06
Time: 15:43:01
